One piece or 2 piece
Old August 20th, 2017 | 11:06 AM
Tripleblack74's Avatar
Should I go for 1 piece carpet or 2? 1974 triple black cutlass supreme, buckets and console. Thanks
Old August 21st, 2017 | 04:21 PM
Bill G's Avatar
The carpet in my 74 Salon is two pieces.. you can see the seam in the attached pic... much easier to install..I'm pretty sure factory was two as well..I'll check the assembly manual when i can..
I do know that you have to cut out the jute padding under the console to make it fit properly..also, that the reproduction carpet comes with the dimmer switch grommet but you have to cut and install it yourself..
Old August 21st, 2017 | 06:53 PM
kncklhd1
March 21st, 2014 10:59 PM
jaunty75
December 18th, 2013 05:18 PM
Blake Willoughby
August 29th, 2013 06:24 AM
Indy_68_S
Brakes/Hydraulic Systems
January 2nd, 2011 10:23 AM
Nickthefish
June 27th, 2010 06:28 AM
