Oldsmobile Chevy?
Oldsmobile Chevy?
So I basically have a question that came about after a 12-pack with my buddy. He turns to my cutlass and stares at it and says do u think a chevelle nose can fit on your cutlass? Just wondering if possible?
Firebirds and Camaros are a lot closer. The A-body cars all have different fender profiles and often the leading edge of the door is shaped differently. It's even worse than that, as Chevelle wagon and Camino front fenders are different from Chevelle 2 dr fenders and don't really interchange.
An olds powered chevy makes more sense than 12pack(s) fueled frankencutlass
CHEERS
https://classicoldsmobile.com/forums...continous.html
CHEERS
But man,it just looked weird.
"Perfectly" is apparently open to interpretation. Here's a 67 GTO:
Here's a 66 Cutlass (67 sheet metal is the same):
The fender lines aren't even close. Note both the shape of the top of the fender and the feature line in the Olds fender (and door) just above the chrome strip. Sorry, but apparently your definition of "perfectly" isn't too perfect.
I agree with you Joe, there was a bit of massaging and sheet metal work required. I wish I had pictures from my HS days. And yes the Camaro was an easier swap.
Would you expect anything less from a bunch of wrecking yard rats with limited budgets and a lot of time and warped imaginations.
ccnclassicoldsmobile
July 26th, 2012 11:49 AM
July 24th, 2012 01:14 PM
