Olds rearends back in the day
Old June 6th, 2010 | 10:18 PM
mmurphy77's Avatar
Seems like the rear end of choice in the 50s and 60s in everything from Hot Rods to Dragsters was the Olds rear end. Obviously it must have been a superior choice over others but I'm just wondering what made them so much better and desireable?
Old June 6th, 2010 | 11:01 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I believe you're referring to the Pontiac dropout rearend. It was stuffed under Oldsmobiles as well.
It was desireable because it's huge. 9.3" Ring gear.
Old June 7th, 2010 | 08:13 AM
mmurphy77's Avatar
Wow, that IS huge. I always just hear it referred to as an "Olds rear". I didn't realize it was Pontiac also.
Old June 7th, 2010 | 08:54 AM
citcapp's Avatar
You could also change rear end ratios for racing and driving much like the ford 9".
Old June 7th, 2010 | 12:16 PM
442much's Avatar
In the 50's the engine of choice was also Olds.
Old June 7th, 2010 | 03:54 PM
mmurphy77's Avatar
Yeah, my Dad's first car in High School was a '51 Henry J with an Olds 'Rocket' motor and tri-power sticking out of the hood! It also had the Olds rear.
Old June 7th, 2010 | 05:24 PM
71supreme's Avatar
The Stone Woods & Cook *****'s originally ran an blown Olds 394. Impressive stuff!
Wasn't the Henry J the car you could order from a Sears catalog?
Old June 7th, 2010 | 06:28 PM
442much's Avatar
Before there was a "Bandit" there was the Beatnic Bandit. With (I believe) an Olds 394
Old June 7th, 2010 | 08:52 PM
64Rocket's Avatar
The whole frame and engine is from a '53 Olds.
Gene
Old June 7th, 2010 | 10:50 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Sears actually had a car called the Allstate which was identical to the Henry J. Only a handful were made and one would be quite rare.
If I remember correctly, the famous 57 Chevy, Project X originally had a 57 Olds rear in it. It could have been a Pontiac. I did not realize those things had such a large ring gear.
Old June 8th, 2010 | 09:33 AM
71supreme's Avatar
Hey! That Beatnik Bandit was a Barris creation right? What was it used for? was it just a show car?
Ahh, thanks for clarifying redoldsman! I knew they were somehow connected
Old June 13th, 2010 | 02:05 AM
88 coupe's Avatar
Junior Member
Originally Posted by J-(Chicago)
I believe you're referring to the Pontiac dropout rear end. ........
"Dropout" sounds strange when applied to the conventional setup of the day.
Olds rear ends were manufactured by Pontiac from the thirties up to '64.
........ It was stuffed under Oldsmobiles as well. ........
"Stuffed" sounds strange when applied to a part that came off the line on every Olds and Pontiac.
The Stone Woods & Cook *****'s originally ran an blown Olds 394. ........
Along with a Hydra-Matic and a Pontiac/Olds rear end with Anti-Spin (or, if you prefer, Safe T Track) differential.
........ Wasn't the Henry J the car you could order from a Sears catalog?
Henry J and Allstate came off the same assembly line. Only difference was the nameplate and registration. During the '80s there was an Antique Drags competitor with a license plate that read "NOT A J".
........ If I remember correctly, the famous 57 Chevy, Project X originally had a 57 Olds rear in it ........
'57 Pontiac/Olds rear in '55-'57 Chevs were common at that time, as it was a direct bolt in.
Norm
HotBoy RuNNA
Drivetrain/Differentials
February 12th, 2011 06:57 AM
<72S>
November 24th, 2010 08:01 PM
hurstoldz
September 22nd, 2009 07:33 PM
74omega
December 28th, 2008 07:53 AM
