Olds heads
Old May 31, 2017 | 04:36 PM
MudEye's Avatar
Olds heads
Looked at some Olds heads ( so He said ) with the numbers n6788 61 Anyone know what engine they belong to? ( He didn't know ) And if they are decent,good or great heads to work with building a performance engine..?
Old May 31, 2017 | 09:25 PM
64Rocket's Avatar
Nothing Oldsmobile as far as I can tell.
Best to post a pic. of them.
'64 to 76 Olds heads have a letter or a number near the spark plug on one side.
May be from a early head, if you can get some pic's, somebody will be able to help.
Gene
Old Jun 1, 2017 | 07:07 AM
What "numbers" were those? Casting numbers? Stamped engine unit numbers? Located where? Did these even LOOK like Olds heads?
Old Jun 1, 2017 | 08:30 AM
MudEye's Avatar
It did look like your picture.....Where exactly are the head numbers identified?
Old Jun 1, 2017 | 08:49 AM
Casting numbers are located above the center two exhaust ports and are raised. Note the lower head in this photo.
A stamped engine unit number was used on the 1964-67 engines and was stamped on the end of the passenger side head.
Assuming your N678861 is the stamped engine unit number, the "N" prefix would indicate a 1966 425 4bbl motor. I assume these are "B" casting heads? Casting number above the center two exhaust ports would be 389395 in that case.
Old Jun 2, 2017 | 05:38 PM
MudEye's Avatar
Yes Joe the numbers were on the end like your picture.. ( sweet picture ) Is that your engine? Great shape...He said there was a block number of 389244 D.....Good ? Ok? Bad? Lol!
Old Jun 2, 2017 | 07:12 PM
No, unfortunately I just stole that one off the web.
A 1966-67 425 block, consistent with the "N" prefix on the heads.
QS442
Jun 12, 2014 06:47 PM
olds4life
Dec 25, 2012 12:56 AM
gearheads78
Nov 10, 2009 09:31 PM
DarkStar
Oct 21, 2009 07:35 AM
