olds head id
olds head id
Hi there, I have a 1973 350 motor, it siezed on me, i have now a 403 (1978), i want to put 64 cc heads on the 403.(its for a stock car) the heads that are on my 350 do not have a visible casting number just below the valve covers, they do have a #5 on the left hand lower corner of each head. I cant at this time pull the valve covers off to check for other casting numbers until I get it in the shop. any ideas asto what these heads might be?
Thanks Ray
Thanks Ray
Thanks 442harv, I took brake clean and a scraper to the area where the casting numbers should be, I looked up some pictures just to make sure and they are not on these heads, I am in Canada and maybe they came from a different plant or something. the cast numbers as far as I can tell have never been there
#5 heads were used on all 1968-69 350 motors. The early SBO heads (#4, 5, 6, 7, 7a) all flow within a few percent of each other in stock form. Any would be a good choice.
Fact of life, only early 330 chambers were ever that small.
Remember, you will need to drill the head bolts to fit the 1/2 bolts (17/64ths bit), and open up the left alignment dowel to 5/16ths".
The 403 intake valves would help, as would new guides.
Jim
