olds head id
Old Nov 9, 2010 | 04:40 PM
Rayce's Avatar
Smile olds head id
Hi there, I have a 1973 350 motor, it siezed on me, i have now a 403 (1978), i want to put 64 cc heads on the 403.(its for a stock car) the heads that are on my 350 do not have a visible casting number just below the valve covers, they do have a #5 on the left hand lower corner of each head. I cant at this time pull the valve covers off to check for other casting numbers until I get it in the shop. any ideas asto what these heads might be?
Thanks Ray
Old Nov 9, 2010 | 05:04 PM
442Harv's Avatar
You don't have to pull the valve cover to find the casting number. It is buy the center exhaust ports. Not a SB expert, but I think #5 are 1969. Maybe #403859?
Old Nov 9, 2010 | 05:06 PM
442Harv's Avatar
Sorry may have posted wrong number. The number I listed was 1970,1969 is,397742
Old Nov 9, 2010 | 05:17 PM
Rayce's Avatar
Thanks 442harv, I took brake clean and a scraper to the area where the casting numbers should be, I looked up some pictures just to make sure and they are not on these heads, I am in Canada and maybe they came from a different plant or something. the cast numbers as far as I can tell have never been there
Old Nov 9, 2010 | 10:32 PM
Redog's Avatar
5's are rumored to be the best SB heads.
C's are rumored to be tbe best BB heads. (well best that are affordable)
Old Nov 10, 2010 | 06:16 AM
#5 heads were used on all 1968-69 350 motors. The early SBO heads (#4, 5, 6, 7, 7a) all flow within a few percent of each other in stock form. Any would be a good choice.
Old Nov 10, 2010 | 06:42 PM
Rayce's Avatar
Thanks for the info on this, I will be pulling the heads soon and I hope to find some casting numbers, but from what you all have said these are the 64cc heads i want for my 403.
Thanks Ray.
Old Nov 10, 2010 | 08:03 PM
Warhead's Avatar
Thanks Ray.
These will be between 68-70 cc's from the factory.
Fact of life, only early 330 chambers were ever that small.
Remember, you will need to drill the head bolts to fit the 1/2 bolts (17/64ths bit), and open up the left alignment dowel to 5/16ths".
The 403 intake valves would help, as would new guides.
Jim
Old Nov 10, 2010 | 09:35 PM
fiona72's Avatar
head number
My engine number 557752-b3 says it is a 78-80 350. My heads also say "GM5" also there is a (looks like) a pmv right below the dipstick, Are these good heads?
young olds
Jun 3, 2014 08:13 PM
Olds Scott
May 29, 2013 08:15 PM
Ragtopw1972
Oct 18, 2012 08:19 AM
CLcutlass
Aug 21, 2011 06:25 PM
