oil filter adapter housing gasket
Old Feb 24, 2025 | 03:43 AM
blp's Avatar
blp
Is it nessecary to have a metal gasket between housing and engine block?
Old Feb 24, 2025 | 06:53 AM
442Harv's Avatar
Yes, or they would not have put one on. Also I use a little gasket sealer.
Old Feb 24, 2025 | 07:53 AM
Warren Seale's Avatar
I had to replace the gasket on my 403 in the T/A. The original was copper but I replaced it with a FelPro fiber gasket. It works fine. I don't know why they originally used a metal gasket.
Old Feb 24, 2025 | 08:46 AM
VC455's Avatar
Barely Registered
Cheap. Effective. Reusable.
They also used metal head gaskets.
Old Feb 24, 2025 | 11:09 AM
Sugar Bear's Avatar
Is it necessary to have a METAL gasket? No, but a gasket? Yes. Be sparing with sealer in that area, use just and only enough to thinly coat the gasket.
Old Feb 24, 2025 | 08:37 PM
And neither the head gaskets nor the oil filter adapter gasket (nor the metal intake gasket) were ever intended to be reusable. Each of these uses a formed bead around the openings in the sealing surfaces. The bead deforms when the parts are torqued to take up any machining tolerances or unevenness. Once the bead is deformed, reuse is not a great idea. Yeah, I realize that solid copper head gaskets can be reused. That is not what we are talking about here.
Old Feb 27, 2025 | 12:17 AM
blp's Avatar
blp
ty so much Joe...
blp's Avatar
blp
thanks a lot Sugar... much appreciated
Old Feb 27, 2025 | 12:18 AM
blp's Avatar
blp
Gary, thanks the time...
Old Feb 27, 2025 | 12:19 AM
blp's Avatar
blp
ty very much Warren
blp's Avatar
blp
much apppreciated sir
blp
Aug 22, 2023 09:25 PM
72455
Jun 23, 2023 07:09 AM
oldguy442
Dec 28, 2021 11:10 AM
ostie13
Oct 2, 2016 08:49 AM
davidstereo
May 14, 2012 08:09 PM
