Oil dip stick
Old Jul 16, 2018 | 12:04 AM
Tymiles24's Avatar
Oil dip stick
Does anyone know if a oil dipstick for a rocket 350 work for jetfire 330?..I already have the tube but no dipstick
Old Jul 16, 2018 | 04:33 AM
dal442's Avatar
all kinds of fun could follow this thread------
just to clarify the question---are you asking whether the dipstick will fit the diameter of the tube OR whether you will get the correct reading as to the oil level in the pan? quick solution --- change the oil & filter on the 330 --to proper amount of oil. give her all the dipstick she can handle --- score the dipstick at the proper level. that 330 will have a smile for quite a time.
length & girth ---important factors here
dal442
Old Jul 16, 2018 | 06:12 AM
The dipstick (called an "indicator" in the parts book) must match the tube. If you swap both the tube and the dipstick from the 350 to the 330, then yes it will read correctly. The oil pans are the same on both motors, as is the location on the block where the tube inserts.
Old Jul 16, 2018 | 07:26 AM
Tymiles24's Avatar
dal442
tube is the original one for the 330....just no dipstick...I see only 350 ones on supercars so that's why I was wondering if the 350 dipstick will work with the 330 tube.
Old Jul 16, 2018 | 07:47 AM
Unlikely. Of course, all you have to do is drain the oil, install new oil and filter, run the engine for a few minutes to distribute the oil, let it sit, and then mark the new dipstick at that oil level.
Old Jul 16, 2018 | 07:50 AM
Tymiles24's Avatar
good point..
Old Jul 16, 2018 | 11:28 AM
Have you checked with any of the folks on this site who are high volume Olds parts sellers?
Old Jul 16, 2018 | 11:39 AM
Tymiles24's Avatar
I just ordered the 350 one from fusick...I'll end up just remarking it
Old Jul 16, 2018 | 12:34 PM
RetroRanger's Avatar
72 Olds CS
I wonder is the dipstick is the same as the original tube ? I got a replacement set-up but the original dipstick wouldn't seat correctly in the new tube.
Old Jul 16, 2018 | 01:40 PM
Tymiles24's Avatar
I bought the replacement chrome one from autozone but that one wasn't even close to fitting
71oldsS
May 11, 2015 06:33 PM
kitfoxdave
Feb 17, 2013 06:15 PM
Stevec
Oct 27, 2012 07:20 PM
jtriggy
Apr 28, 2010 07:10 AM
woodie582
Nov 10, 2008 06:48 PM
