NOS 1966/1967 W30 Cam and Springs
NOS 1966/1967 442 W30 Cam and Springs just sold on Ebay tonight for $620.00. Anything special about the Cam or springs? Since these are internal parts....I did not think they would bring so much money. Any other make or model use these springs?
Thank you,
Scott
Thank you,
Scott
no magic in the springs. comp cams sell's a retro w-30 cam 308-308 advertise duration. 233-233 @50 and 474-474 lift on a 113 LSA. if your looking just for the same sound and idle this one would be good. if your looking for more power there is a lot of better more modern cams out there.
Here's a PDF version, in case people still have trouble reading it.
http://wildaboutcarsonline.com/membe...tailed_1-2.pdf
Thank you,
Scott
Thank you,
Scott
At the end of the day, it's the camshaft for the quickest most powerful factory Oldsmobile of all time.
And more to the point, is it worth paying nearly $1000 for an NOS factory can then putting it in an engine where no one will see it? An aftermarket cam ground to the same profile could be had for a fraction of that cost, and would perform the same and also wouldn't ever be seen.
mother$hip89
December 30th, 2018 08:45 AM
