Is this normal? Vent window
Old Dec 1, 2019 | 06:19 PM
Platinum69's Avatar
There is a gap between door panel and window rubber. The panel appears to be tight against door. Thinking maybe window rubber? Brand new door panels from legendary. Thanks
Old Dec 2, 2019 | 06:01 AM
allyolds68's Avatar
It looks like the inside window sweep is too long. If no one's replied by tonight I'll look at my car and post a pic (Mines a 68). I assume yours is a 68 or 68-69 post
edit:
I just look at at a pic of mine and it looks like the vent window rubber fills the gap but the pic isn't a close up so I can't be sure. The inside stainless bead DEFINITELY doesn't extend past the vertical vent window stainless (my panels are Legendary as well)
Old Dec 2, 2019 | 06:16 AM
Gpc1's Avatar
Aftermarket parts sometimes need adjustments, looks like if you trim back that chrome bead it will fit like it’s supposed to. When you reinstall do that top edge first . The panel should hook over the top first then align the rest. Hope this helps....
After seeing post from rcorrigan5 , It looks like the bead is supposed to go in front on the vertical vent window bar but yours extends farther forward. Don’t cut or trim anything ! Does the other side have the same issue? Pull off both panels and look for that top bracket the panel is supposed to hook onto. If you have the old panels do a comparison , you might have the wrong panels for your model as others have stated.
Old Dec 2, 2019 | 12:06 PM
Platinum69's Avatar
[QUOTE=allyolds68;1212658]It looks like the inside window sweep is too long. If no one's replied by tonight I'll look at my car and post a pic (Mines a 68). I assume yours is a 68 or 68-69 post
edit:
Door panel could go back a little but the panel would be past the door edge on the back edge.
Old Dec 2, 2019 | 02:34 PM
rcorrigan5's Avatar
Randy C.
The inside window sweep on my '68 4-4-2 extends ever so slightly beyond the vertical stainless but not enough to pull the panel away from the vent window rubber. It just looks to me like your inside window sweep is interfering with the door panel being closer to the vent window rubber.
Randy C.
Old Dec 2, 2019 | 03:01 PM
Yellowstatue's Avatar
From far away, it looks as though you have a hardtop panel on a post car door. The panels are definitely different not to mention, not the same. Just looked at a picture of my W30 and the gap at the back of the door is half of what yours is. I don't have a picture of the vent window view on file..
Old Dec 2, 2019 | 04:13 PM
olds70supreme's Avatar
There is a bolt-on tab/bracket that the door panel hangs on right under the vent window. If the panel isn't "latched" onto that bracket there will be a gap there because the bracket pulls the panel tight to the window. Check that first before trimming anything. I believe the bracket is slotted for adjustment in and out.
Old Dec 2, 2019 | 04:27 PM
72455442RA's Avatar
looks like its a hardtop door panel on a post door ...
the post wing window real estate is larger
how do the repop rears fit
issues at the door pillar post also ??
the rear of the front door panel shows the issue also
Old Dec 2, 2019 | 04:58 PM
Platinum69's Avatar
hhmmm, do you have a picture of this bracket, not awhere of it? I'm sure it's not on it. Not so sure the panel will pull in that much.
I'm a little upset with the fit of these panels for what they cost, thought I'd go with pre assembled from legendary.
Old Dec 3, 2019 | 08:01 AM
https://classicoldsmobile.com/forums...stions-134857/
The first picture in this post shows an area w/ a greenish/yellow line - that is the area the bracket mounts to. The bracket is the one on the right in the second picture in the post.
My car is not a post car, it could be different.
Old Dec 5, 2019 | 09:18 AM
Platinum69's Avatar
ok, so I found a bracket that looks like the one on the right, not sure which door it's for but I'm going to try it tonight.
Old Dec 5, 2019 | 10:59 AM
allyolds68's Avatar
This /\ /\ /\ is my bet. I might have a couple of these brackets laying around if you need one; This is a pic of the one on the passenger side. The driver's side is the same but opposite
Old Dec 7, 2019 | 04:05 PM
Platinum69's Avatar
Found the bracket, looks much better now
The original kinda fits the same, must be the door is a little off?
cbogartjr
Aug 27, 2020 04:52 PM
393tony
Apr 16, 2013 06:04 PM
StarGeneral
Body work
Jan 25, 2012 10:58 AM
cbogartjr
Aug 13, 2010 12:34 PM
cbogartjr
Aug 11, 2010 06:11 PM
