No power windows, power seat or door locks
Look for a dead relay. You’ll probably need a wiring diagram to figure out where and what it is.
Could also be a broken wire which feeds all those circuits, but I’d bet on a relay first.
Chris
Chris
The relay should be common to your era GM’s, the trick is knowing which one to get. I can’t help you there since my cars are a lot older.
There are likely several relays, but probably only one to those accessory circuits.
