newbie steering pump q
I'd be willing to bet any gm pump of that vintage would be about the same... Not sure when they went to the newer style, or if its a direct bolt in to the one you have. If nothing else this should be good for a BUMP. Good luck
Or consider having it (and perhaps the steery box as well) rebuilt!
It will be more expensive this way, but they will be guaranteed to fit, function, and look perfectly for many years to come. You could even upgrade to a 12:1 constant ratio in the box if you wanted.
If they are 40 year old originals, it could just be time to do the system.
The basic Saginaw PS pump was used from the early 1960s through at least the 1990s. The pump body is the same on all, but the sheet metal reservoir varied by application. Usually you get a rebuilt pump and swap the reservoir - it's a bolt-on though the O-ring can be stuck.
Nor Cal Andy
March 29th, 2012 07:27 PM
