newbie steering pump q
Old Oct 27, 2011 | 04:16 PM
65OldsDelta88SuperRocket's Avatar
on my 65 thr steering pump is leaking badly and I was figuring id just replace. what other cars share this same pump?
Old Nov 2, 2011 | 02:48 AM
oldsmobum's Avatar
I'd be willing to bet any gm pump of that vintage would be about the same... Not sure when they went to the newer style, or if its a direct bolt in to the one you have. If nothing else this should be good for a BUMP. Good luck
Old Nov 2, 2011 | 03:34 AM
My question would be, where is it leaking from?
You may just need to get a seal kit for a few bucks from the auto parts store.
Old Nov 2, 2011 | 05:14 AM
Lady72nRob71's Avatar
Or consider having it (and perhaps the steery box as well) rebuilt!
It will be more expensive this way, but they will be guaranteed to fit, function, and look perfectly for many years to come. You could even upgrade to a 12:1 constant ratio in the box if you wanted.
If they are 40 year old originals, it could just be time to do the system.
Old Nov 2, 2011 | 06:53 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I have this one laying around. Not sure exactly what it came from over the years, but it's definitely period correct.
Old Nov 2, 2011 | 07:00 AM
The basic Saginaw PS pump was used from the early 1960s through at least the 1990s. The pump body is the same on all, but the sheet metal reservoir varied by application. Usually you get a rebuilt pump and swap the reservoir - it's a bolt-on though the O-ring can be stuck.
Apr 23, 2013 06:16 PM
Scottem
May 29, 2012 11:24 AM
Nor Cal Andy
Mar 29, 2012 07:27 PM
sshriber
Mar 22, 2010 06:16 PM
72Ctlss
Jun 23, 2009 03:12 PM
