New Winter ride
Old August 24th, 2016, 11:01 AM
88 Cutty Classic's Avatar
New Winter ride
Drove out to Philthadelphia yesterday and picked up this sweet lil thang for $1800. 81K and shes mint underneath
88 Cutty Classic is offline
Old August 24th, 2016, 11:30 AM
scott_442's Avatar
Wow! That is clean. Nice find! Should have no problem with the winter elements.
scott_442 is offline
Old August 24th, 2016, 05:28 PM
That's awesome. Too bad it won't be "mint underneath" for long if it's a winter ride...
joe_padavano is offline
Old August 24th, 2016, 05:49 PM
Hookers under Hood
76olds's Avatar
Nice car with low K's. I'd hate to drive it through the winter in that shape. You will get many winters out of it for sure.
That's nicer than my DD!!
Cheers
Eric
76olds is offline
Old August 24th, 2016, 06:04 PM
Looks too nice for a winter beater! But I know you cant save 'em all...
Greg Rogers is offline
Old August 24th, 2016, 07:45 PM
A perfect winter beater. Gonna need some snow tires though.
oldcutlass is offline
Old August 24th, 2016, 07:52 PM
Chris J's Avatar
great find, that will be an awesome winter ride. I still cant figure out why never find these deals!:
Chris J is offline
Old August 25th, 2016, 04:47 AM
i POR 15'd the frame and any place that would be suspect to rust. I also cleaned all the door drains to make sure nothing was plugged up. it is a nice car but its gonna save my Marauder from the winter. I'm dumping the electronic carb and dist because its running sluggish and throwing a tps code. probably worked fine in 87 but i'm not chasing down problems in that old of a system.
it took me quite a while to find a nice 4 door. last winter was pretty mild so as long as the salting keeps to a minimum i should be good. most of my trek each day is 80% highway. i may bump up to run 15inch snow tires because i think i still have a set of studded ones at my dads shop.
Old August 25th, 2016, 04:53 AM
Oldsdruid
rocketraider's Avatar
Clean! Look at the side profile pic and you'll see that, like most GM cars, these cars were NEVER MEANT TO WEAR A VINYL ROOF.
Joe P, ain't you pretty good with electronic Q-Jets? That TPS might be a simple fix. Is this a 307 or V6?
rocketraider is offline
Old August 25th, 2016, 06:56 AM
it's a 307. im fine with dumping the emission crap anyway. it will give it a lil more life. with 2.14s its needs all the help it can get.
Old August 25th, 2016, 08:11 AM
Local Hero's Avatar
Nice find and it's true, you can't same 'em all. My 78 was originally intended to be a year round DD until I woke up. Now it's only a DD April through November.
Local Hero is offline
Old August 25th, 2016, 01:50 PM
same but different
don71's Avatar
This time of year, hardly anyone thinking bout the next winter, and you already have a ride. Its pretty cushy too. Meaning...comfy seats and stuff. Only needs studded snowtires. I'd rock it.
don71 is offline
Old August 28th, 2016, 11:17 AM
65Delta's Avatar
2.14s??? Wow, and I thought the 2.56s that came in my '69 were rough. The rear windows are fixed "picture" windows in these, correct? Clean ride . How did you find it? Estate sale?
65Delta is offline
Old August 29th, 2016, 06:41 AM
the early bird gets the worm!
g72...2.14... horrible. lol
yes the windows are fixed...no reason anyone at GM should have thought this was a good idea. my Mercury Marauder's rear door have glass the goes all the way down. I remember my moms 84 delta going half way. they are basically similar door designs. Ford out engineered GM something fierce on this one.
I found it on craigslist, mainly because i was looking for a 4 door g-body, preferably a cutlass. I woulda loved an 83 cutlass cruiser wagon but this is pretty close to what i wanted. the only thing i woulda changed is having it code 31 dark teal metallic and giving it overdrive, maybe a few power options but for a 30 yr old car i cant complain.
car belonged to a priest at some point. probably why its close to rust free.
Old August 29th, 2016, 06:50 AM
The amount the rear door glass can go down is a function of styling of the car. The rear wheel opening intrudes into the door. Normally, this would limit how far down into the door the window can drop. On the Marauder, Ford used that small fixed window at the back of the rear door and a correspondingly smaller sliding window that cleared the wheel arch.
On the Olds, you can see that despite the small quarter window, the main sliding window is still limited by the wheel arch.
Old August 29th, 2016, 07:45 AM
you showed how easily it was done via the design . Someone at GM signed off on this BS. "yeah, people wont care about a window that goes half way down"
you wanna see a car thats really awful, try the 94-96 impalas (and caprices) it might go down 30%.
Old August 29th, 2016, 07:49 AM
And both people who bought them withOUT A/C probably care about that...
Olds 88 Rocket
Vista Cruiser & Wagons
27
June 12th, 2012 06:03 AM
Olds 88 Rocket
July 27th, 2010 10:18 PM
sean65
December 2nd, 2008 01:26 PM
f-85
December 1st, 2008 06:20 PM
scott_442
March 23rd, 2008 03:02 PM
Quick Reply: New Winter ride
