Need to replace this
Old Apr 13, 2021 | 06:38 PM
NoVA_69_442's Avatar
Was wondering what this piece is called and where to get a replacement for it. I found the hose and steel tube set up on fusick, but can't find the piece the goes into the booster. So i need to get a new one or figure out the trick to getting this one back in. It won't seem to go back in. Thanks.
Old Apr 13, 2021 | 06:50 PM
http://www.fusickautomotiveproducts....number=BCV642B
You need a "brake booster check valve." See that link.
Old Apr 13, 2021 | 07:35 PM
Also available at your local auto parts store:
https://www.autozone.com/brakes-and-...er-check-valve
https://www.oreillyauto.com/detail/c...ck+Valve&pos=4
https://www.napaonline.com/en/p/UBP8...ABEgImsPD_BwE&
Old Apr 14, 2021 | 04:35 AM
Thanks for the responses, gonna pick one up at Autozone on the way home from work.
Old Apr 14, 2021 | 04:53 AM
rob1960's Avatar
You can probably just get the rubber grommet by itself, that's what actually failed on your car. You need the top one in the pic. The inside piece of your grommet fell down inside your booster when it disintegrated, it shouldn't hurt anything though.
Nov 8, 2020 11:58 AM
72455
Nov 3, 2019 01:39 PM
Dadsbadass442
Apr 15, 2018 03:51 AM
jaunty75
Dec 18, 2013 04:18 PM
Indy_68_S
Brakes/Hydraulic Systems
Jan 2, 2011 09:23 AM
