need help with my engine, non olds.
Old November 13th, 2013 | 06:16 AM
  #41
young olds's Avatar
Red face
Off idle is where dropping the main jet size helped. When I first got the carb I didn't know about idle jets and air bleeds so I just increased the main jets until it drove without stumbling or surging. From the research I've done the idle jets influence more than just at idle, I read up to 80% throttle range, so when I increased my idle jet for the correct air/fuel at idle it made it to rich off idle. Going back down on the main jets leaned it out off idle so it wasn't overly rich.
Old November 13th, 2013 | 11:08 AM
  #42
Clearly, you need more information than we can give you here, so I took a look around for you.
The 32/36 carb has a unique design, and our advice based on more conventional carbs has only limited utility for you. For one thing, the idle jets DO control up to 80% of throttle.
Here's a diagram of all the jets and other adjustments, with number for a Saab V-4 application:
Here are a number of links that should give you an idea of where to head, but the set-up for the Iron Duke engine will likely be different from all of these:
An MG site.
An Explanation of the metering system, with some adjustment advice (see page 6).
Float Level
Carburetor Set-Up and Lean Best-Idle Adjustment (from Weber).
Troubleshooting Guide (from Weber).
Weber 32/26 Carburetor Adjustment (from a Jeep CJ site).
Old November 13th, 2013 | 12:36 PM
  #43
young olds's Avatar
Thanks for the links, I'll check them out when I get home from work.
e.cast728
April 7th, 2014 04:14 AM
VikingBlue
September 20th, 2013 12:55 PM
razziz
February 7th, 2013 11:13 AM
ELECMAN
January 22nd, 2012 01:49 PM
Quick Reply: need help with my engine, non olds.
