NEED HELP....FWD vs RWD
I'm not aware of any FWD car with the 5 x 4.75" bolt pattern. 4.75" is a 120.65 mm bolt circle. There ARE FWD wheels with 5 x 120 mm bolt circle. These should not be used on a 4.75" bolt circle car in any case.
Joe if you look at it as just a large positive offset vs fwd or rwd then yes there are. All S10 4x4 use a large positive offset and a 5 x 4.75 bolt pattern. Also the C4/C5/C6 Corvettes use that same style of wheel but is of course much larger and varies depending on the year.
As a matter of fact, I have a set of 2" spacers between the rear wheels on my dually due to the oversize tires I'm running. I've had them for years and towed a lot of cars and a lot of horses with no problems. As I noted these have a machined center bore that fits over the hub and a machined male feature that centers the outboard wheel on the spacer. In my case there are actually double wheel studs due to the thickness of the spacer. The stock studs hold the spacers and inboard wheels to the hubs. The spacers have a second set of studs clocked between the eight original ones that hold the outboard wheels to the spacers. I actually got these from Fred Groeske, the former rocket-powered funny car driver who now has a small shop in the San Fernando Valley making wheel spacers. I picked them up in person and Fred was very interested when I told him that I'm an aerospace engineer. He opened one of his desk drawers and pulled out a hydrogen peroxide rocket engine that he developed himself.
What about Toronados? I don't know about the early ones, but the 80s version were in fact 5 x 4.75. I worked with a guy at American Racing Wheels back in 1991 that had one and was complaining that the only wheel available for it were the ones that fit 4x4 S10s.
![](http://extranet.soleniuminc.com/CentricParts/part_images/12066006.jpg)
Of course, as you have found, the OP was asking about a "FWD" wheel for a 4.75" bolt pattern and they don't exist, so I still maintain that the OP was actually looking at a 120 mm wheel.
henryk8398
May 3rd, 2012 12:26 AM
hardwatr
January 15th, 2012 07:41 PM
