Need advice on a posi unit for a C body
Old March 25th, 2019, 12:53 PM
zeeke's Avatar
Looking to have a unit built for a 73' C body. Since these posi rears are more rare than Bigfoot sightings we are looking to have one built. What's the general opinion 9" or 12 bolt? The bolt pattern on the wheel hub would have to be 5X5 to match the fronts and the wheels. I'm thinking 9" parts would be more easily obtained in the future if needed and not sure if I could get 5X5 axles for a 12 bolt. Brakes will be converted to disk. Also, wondering what other challenges we might not anticipate other than the portioning valve.
Side note: I see Deadeye has hit the 1000 mark, so I went back and looked at my number. I've hit the 911. To the general population this may be much of a mile stone but for a first responder it stands out.
zeeke is offline
Old March 25th, 2019, 02:22 PM
2blu442's Avatar
Which rear end do you have in your car now? Would this one from a 1975 Riviera fit? This guy is located in Brooklyn.
https://www.ebay.com/itm/12-BOLT-GM-...QAAOSwFSNb81-p
2blu442 is offline
Old March 25th, 2019, 02:42 PM
Moser will drill any bolt pattern you want into the flanges.
joe_padavano is offline
Old March 26th, 2019, 04:42 AM
zeeke's Avatar
The original from 73' but it needs a 9-3/8 which are very difficult to find. That's why having one built with readily available parts is the option we are looking at. Went down this road last year and after much homework and advisement found out the rears were made by Olds for the BOP's and only from 71' until 76' or 78'. Riveras had them which are a bolt in but he big cars only got them if you ordered that option. My thinking is even if you find one they are more expensive than building one and if something breaks you are back at square 1.
zeeke is offline
Old March 26th, 2019, 04:58 AM
Here's a good thread with info on the 9.3 and 9 3/8 full-sized rear.
https://classicoldsmobile.com/forums...erchanges.html
Our member; Monzaz, is the go to guy for info on these hard to find parts. I've often wondered what I will do with my 71 98 if I ever get to the point of restoring/replacing the rear end?
Olds64 is online now
Old March 26th, 2019, 10:27 AM
zeeke's Avatar
Thank you
zeeke is offline
gevosrears
November 13th, 2013 05:05 AM
tru-blue 442
Drivetrain/Differentials
May 7th, 2012 08:48 AM
monzaz
April 24th, 2011 06:12 PM
egknz
August 31st, 2010 01:30 PM
monzaz
October 28th, 2009 06:58 AM
Quick Reply: Need advice on a posi unit for a C body
