Missing Cowl Tag
Old Apr 8, 2024 | 11:53 AM
Newcurt's Avatar
Missing Cowl Tag
My 1969 442 is missing the cowl tag which really sucks. Is there any way of getting the information (color, options, etc) that is found on the cowl tag by searching the VIN or any other method. Thanks
Old Apr 8, 2024 | 01:21 PM
69HO43's Avatar
Is it a Canada car? They MAY have some records on it.
If Canada has any info on it, try here.
Vintage Vehicle Services
If not, it's going to be a slog. If it wasn't built in Lansing (M in the VIN), you COULD you run across a build sheet or some broadcast cards or something that could help narrow things down. The only thing the VIN will tell you is year, body style/series, where it was assembled, and sequential plant build number for that series.
Old Apr 8, 2024 | 02:05 PM
As noted, unless the car was built in Oshawa or originally sold in Canada, the only way to get that info is to find a build sheet. That will be nearly impossible for a Lansing car. Other assembly plants and you have a chance.
Old Apr 9, 2024 | 04:54 AM
allyolds68's Avatar
Look under the back seat and see if there is a Fisher body tag attached. My Lansing car was pretty rough but it still had one. This is an example of what one looks like (this is a 68), i believe 69 used the same type of card:
With the exception of Oshawa, there really isn't much info on a cowl tag that you can't get close by inspection (original color, trim level, interior color and seat style, etc). Cowl tags are reproduced and with a little research you can even zero in on a build date for your car from the VIN.
Old Apr 12, 2024 | 03:39 AM
AveryMorrison's Avatar
Thank you so much for sharing the vintagevehicleservices link,
Spoiler
tkcutlass
Jan 27, 2024 05:38 PM
oldcutlass
Apr 14, 2022 07:27 AM
72 Post
Jul 8, 2021 06:08 AM
chrisneu68olds
May 10, 2017 09:46 PM
70sdream
May 9, 2016 04:16 PM
