media blasting aluminum....paging Napoleon Solo
Old Feb 21, 2012 | 04:03 PM
jensenracing77's Avatar
i am looking to clean some Aluminum parts. i used glass on my old W-31 intake and now it is very dull. i was wondering what the proper media is to use on aluminum or if there is a better way in general to clean aluminum. my buddy has an industrial ultrasonic cleaner but is not big enough for an intake manifold or heads. is there something i can use and keep that original shine? or is there something that will bring back that shine on the W-31 intake?
100_6727.jpg?t=1329868837
100_6726.jpg?t=1329868884
Old Feb 21, 2012 | 04:40 PM
w-30dreamin's Avatar
71 & 72,now I want a 68
Great question,I'll be watching to see what kind of replies you get.
I have a w-30 intake that needs a little cleaning for my future big block build.
thanks
Old Feb 22, 2012 | 03:50 AM
DeltaPace77's Avatar
Crushed walnut shell media is a popular option when trying not to disturb much, but think just about any kind of blasting is going to dull things a bit. Suppose you could always hit the manifold with a buffing wheel/compound later, but maybe shine too much, and lots of work. Maybe some light blasting media, followed with clear engine enamal would do it. If paint, would at least partially plug up the center exhaust passage though.
Old Feb 23, 2012 | 12:18 PM
Napoleon Solo's Avatar
I'm indecisive. Or am I..
Hi guys,
Sorry I missed the post. My good friend Allan pointed me in the right direction. When I blast aluminium parts specifically intakes, spacer etc. I clean them with a processed (smashed up) garnet first then go over them with glass bead. The bead polishes the aluminium to a nice sheen without being too 'in your face'. I did my own Jaguar intake, thermostat housing and carb spacers and it looks awesome. I attached pictures. These parts are normally black from the factory ( not the twin cam head) but I'm not that much of a purist. The last step is a high temp clear coat that won'tturn yellow. I used VHT clear which is holding up pretty well. Jags run hot to begin with.
Old Feb 23, 2012 | 01:12 PM
frankr442's Avatar
My W30 intake was glass beaded about 20 years ago. Every couple of months I wipe it down with GM heat riser penetrant #88862627. Still looks good.
Old Feb 23, 2012 | 01:20 PM
Eddie Hansen's Avatar
Anodizing?
perhaps anodizing the aluminum once it's been semi polished? I know you can colour aluminum but also there is a clear version and basically it seals the aluminum, when you get aluminum in most DIY shops it is anodized to keep the oxidation low, perhaps seek a service or maybe DIY
http://www.atmsite.org/contrib/Newman/anodize/
Old Feb 23, 2012 | 04:10 PM
thanks guys, i found out that it fit in my friends ultrasonic cleaner and it looks great. it is amazing how well those things work.
Old Feb 23, 2012 | 05:05 PM
this is how it turned out. not completely perfect but i am happy with it.
100_6773.jpg?t=1330045370
100_6772.jpg?t=1330045459
Old Feb 23, 2012 | 05:13 PM
jdana24's Avatar
1968 Olds Cutlass S
I'm not an expert in this area, but the person who I buy my media from at United Western Supply sent me the following email:
"I would try a very fine Aluminum oxide. Either 180 or 220."
Jay D
Drivetrain/Differentials
Oct 3, 2011 05:28 PM
Del70
Jun 3, 2011 01:01 PM
sx455raidercelticfan
Nov 18, 2010 05:43 AM
therobski
Body work
Oct 12, 2010 06:35 PM
bsimo442
Feb 17, 2010 07:18 PM
