Main Bearings
The bearing alignment/locating tabs go together.
The caps only fit properly one way. The caps and block are offset, the cap won’t seat into the cap register unless they are positioned correctly
well I got it figured out after checking tolerances many times come to find out the numbers side of the cap goes on the driver's side of the motor
