Machine Shops In Alberta
Hey anyone in and around the Calgary/Red Deer Alberta area know of any good/reputable engine machine shops? I will need to get some work done in the fall of this year (heads, block, crank, etc.)
Fyi
Visit their website here
http://josstechnical.com/
Ok. I'm actually going to build the engine myself, I just need the following done...
Block - tanked/cleaned, checked for cracks, new cam bearings & frost plugs, new piston rings, hone the cylinders (don't want to get into boring if i don't have to. Might look into new pistons. The motor doesn't knock/tick at all but it is supposed to have 200K miles on it & has never been apart)
Heads - tanked/cleaned, checked for cracks/warpage, grind the valves/seats
Crank - turned & polished, new bearings
Intake - tanked/cleaned, checked for cracks/warpage (I'm staying with the stock 4bbl intake)
