Machine Shops In Alberta
Old May 18, 2012 | 09:31 AM
rcrac3r's Avatar
Hey anyone in and around the Calgary/Red Deer Alberta area know of any good/reputable engine machine shops? I will need to get some work done in the fall of this year (heads, block, crank, etc.)
Old May 18, 2012 | 01:14 PM
oldsmobiledave's Avatar
Fyi
The ONLY Oldsmobile engine builder in Alberta that you should consider is Joss Engines in Lethbridge AB.
Visit their website here
http://josstechnical.com/
Old May 18, 2012 | 01:40 PM
rcrac3r's Avatar
Ok. I'm actually going to build the engine myself, I just need the following done...
Block - tanked/cleaned, checked for cracks, new cam bearings & frost plugs, new piston rings, hone the cylinders (don't want to get into boring if i don't have to. Might look into new pistons. The motor doesn't knock/tick at all but it is supposed to have 200K miles on it & has never been apart)
Heads - tanked/cleaned, checked for cracks/warpage, grind the valves/seats
Crank - turned & polished, new bearings
Intake - tanked/cleaned, checked for cracks/warpage (I'm staying with the stock 4bbl intake)
GATA79
Jun 21, 2012 06:45 PM
libertyson
Apr 29, 2011 06:43 AM
bosch 68 442
Apr 12, 2011 07:44 PM
BerBer5985
Feb 23, 2011 10:17 AM
JacksAuto
Dec 30, 2010 07:13 PM
