Lucas oil additives question 🤔
Old Mar 9, 2021 | 05:39 AM
72455's Avatar
1972 U code Supreme
Hey all I was wondering if it's OK to use both Lucas oil stabilizer and stop leak together? My '72 Supreme 455 has a small oil leak, but I also like the benefits of the stabilizer. I use Valvoline 10w30 VR1. Also, do any of you use Lucas or something else?
Old Mar 9, 2021 | 05:44 AM
Jungle Cat's Avatar
They are all snake oils. Good oil never requires additives as long as zinc and other lubricants are present in adequate quantities. As far as leaks go nothing will fix them but new gaskets.
Old Mar 9, 2021 | 05:47 AM
Jungle Cat's Avatar
As far as oil goes maybe consider switching to Brad Penn. It has the ZDDP additives old cars need. Common parts store oils not so much.
Old Mar 9, 2021 | 06:25 AM
72455's Avatar
1972 U code Supreme
The Valvoline VR1 has the zinc 😀
Old Mar 9, 2021 | 09:05 AM
My personal opinion: if most the additives on the shelf served a purpose or had any benefit, they wouldn’t be on the shelf. The refinery would have added them in the manufacturing process.
Having said that, there are a few additives that are useful. Break in additives, zinc additives, things like that I can see buying and using. In the case of oil additives for a flat tapper cam, it would probably be cheaper just to buy the oil formulated for flat tapper cams instead of buying the extra stuff.
Old Mar 9, 2021 | 09:35 AM
redoldsman's Avatar
Proud Viet Nam Veteran
I wouldn't waste the money on the stop leak. While not doubt Lucas products are good stuff I question if it is really needed with Valvoline VR1 Racing Oil. VR1 has all the zinc you need. Be sure and use a good filter like Wix or NAPA Gold which is the same thing.
Old Mar 9, 2021 | 11:56 AM
72455's Avatar
1972 U code Supreme
Always do sir!😀
Old Mar 9, 2021 | 01:38 PM
Sugar Bear's Avatar
Try to identify and repair the leak first. Oil additives aren't good at sealing leaks particularly on rope rear main seals that Olds used from the factory if that is your leak. Neoprene seals on other makes can be softened sometime to reduce the leak.
IMO a stop leak additive in this case is not a good choice until the leak is identified. Also IMO don't use oil stabilizer either, use the VR1 and the good filter you already use sans additives.
Good luck!!!
Old Mar 10, 2021 | 04:18 AM
F-85 4-4-2's Avatar
Never used an oil stop-leak until my son told me that a pint of the Lucas product stopped a minor leak on his 2003 Wrangler. So I tried a pint on my 1990 Sierra, and it worked there, too. Was worth the $5 risk. Unlike the olden days, Lucas isn't a seal-swelling solvent. It's a viscous oil. Not sure how it works; don't think they're disclosing that.
Old Mar 11, 2021 | 10:48 AM
Oh it's not? I thought it was, but my mistake. Maybe it has chunks like Barrs.
Gary M
Apr 5, 2017 08:05 AM
Gary M
Oct 18, 2015 09:32 PM
scooter123
Mar 5, 2014 11:23 AM
jpc647
May 4, 2013 10:58 AM
olds67
Dec 5, 2009 01:11 PM
