Loose Gas Cap and Dimmer controlling Parking lights 70 Cutlass
Hey Guys, Need some advice on stock gas cap barely tightening before it gets loose again. Are there threded gas cams with small enough diameter to screw in? Or should i try messing with the spout to bend and potentially get the stock cap to fit tighter?
Also with my headlight switch pushed all the way in if i turn my dimmer to the left the parking lights will brighten and dim. this only happens when the lights are supposed to be off. !st and 2nd click work fine otherwise.
Thoughts?
Thoughts?
olds70supreme
January 25th, 2013 07:08 PM
