Loose Gas Cap and Dimmer controlling Parking lights 70 Cutlass
Old Oct 2, 2015 | 11:04 AM
Curts1970cutlass's Avatar
Hey Guys, Need some advice on stock gas cap barely tightening before it gets loose again. Are there threded gas cams with small enough diameter to screw in? Or should i try messing with the spout to bend and potentially get the stock cap to fit tighter?
Also with my headlight switch pushed all the way in if i turn my dimmer to the left the parking lights will brighten and dim. this only happens when the lights are supposed to be off. !st and 2nd click work fine otherwise.
Thoughts?
CyberCholo
Wheels and Tires
Apr 6, 2014 05:37 PM
dnmfranco
Aug 2, 2013 08:03 PM
olds70supreme
Jan 25, 2013 07:08 PM
arodenhiser
Nov 9, 2010 11:53 AM
Gaz Hog
Jun 25, 2010 04:13 AM
