lock mechanism on the front of my car
Old Jan 12, 2013 | 08:32 PM
shakeyhands73442's Avatar
I have what looks like a keyed hood lock kinda thing under my 442 emblem on the front of my car...did they make one of those from factory as an option? it is not connected to anything i have a hood popper under the dash by my ebrake, should i keep it and reconnect it or should i pull the lock and fill the hole thanks
Old Jan 12, 2013 | 08:44 PM
oldspackrat's Avatar
Most likely an aftermarket alarm key switch. I used to see those on cars in junkyards many years ago. Usually they were mounted in the drivers fender. They were pretty popular in the '70's. I'd remove it if you're going to paint/restore the car.
Old Jan 13, 2013 | 05:04 AM
Rickman48's Avatar
If it's in the 'tooth' between the grilles, your better off replacing it, as any repairs are subject to quite a bit of vibration, and usually don't last.
Easier, too!
Old Jan 13, 2013 | 06:01 AM
Olds_71_442's Avatar
Isn't the tooth made of fiberglass? If so, it shouldn't be a problem to repair it.
Old Jan 15, 2013 | 04:40 AM
HonestDave's Avatar
I, personally, would leave it until I had absolutely nothing else to do, which could be never. I've got a factory one in the driver's fender of my 75 Vette, which looks kind of weird, and I've managed to tune it out most of the time. Besides, doing nothing is easier. If you try to fix it, you'll be fussing over repair work and paint matching. It doesn't even be bear thinking about.
Just one man's opinion.
Interesting car, not sure I've seen a 442 that year in recent memory. Got any more pictures?
Old Jan 15, 2013 | 05:30 AM
2blu442's Avatar
In 1973 the tooth was sheetmetal, I think all the fiberglass pieces were under the bumper. Should be easy to fill the hole with metal if that's what you want to do.
John
goldie442
Aug 21, 2015 11:01 AM
benjamin247
Oct 1, 2014 07:23 PM
tds
Aug 16, 2014 07:40 AM
Maverick
Apr 22, 2014 05:04 AM
randomarrival
Dec 22, 2012 12:28 PM
