A little help
Old Jul 6, 2017 | 01:19 PM
westside807's Avatar
A little help
Hello guys!
my ac has started to blow a little out from the heater port on the transmission hump. It still blows through the vents but I feel cold air in my feet which is a no no. I've been doing some work behind the dashboard and I may have iether disconnected a vacuum hose and/or plug the hoses back incorrectly. I have a pic of the rear of my temp control unit. Notice how there are 2 vacuum ports with no hoses is this correct? If not what hoses connects to them, and where don't connect to.
thanks guys! White striped vacuum hose at the top, these 3 are at the back of the temp control inside the car. Should there be something attached to the other 2?
Old Jul 6, 2017 | 01:23 PM
tru-blue 442's Avatar
Old School Olds
Yes there should be hoses attached. Year make and model always helps along with a CSM before starting. Not trying to bust your ***** but....
Old Jul 6, 2017 | 01:33 PM
Yep you're right, sorry. It's a 1971 Cutlass base with factory air. 350 engine and transmission. I'm not sure what a CSM is it means. Btw, I don't see any loose vacuum hoses anywhere
Old Jul 6, 2017 | 01:42 PM
Old School Olds
Don't apologize. Just be prepared. I don't have a 71 CSM, but someone will help out hopefully. A perk about being a CO member is there are no questions that can't be answered here. The tone among members on this site can't be beat. Good luck with your A/C. Here in the South it's a lifer saver. Feeling lucky today, It's only 96* at the moment.
Old Jul 6, 2017 | 01:48 PM
Chassis Service Manual, the mechanics' manual from the factory on care and feeding on your year Olds.
Old Jul 6, 2017 | 02:10 PM
Yes it's 93 in my part of the country, but feels like 103!!! I'm about to convert to a parallel flow condenser, but I want to make sure all the air is blowing where it should. I've looked at a couple house diagrams online but they're hard for me to follow
Old Jul 6, 2017 | 02:20 PM
Lucky you! It's 113º here and it hasn't peaked yet.
Old Jul 6, 2017 | 02:32 PM
Wow, that would suck. 113??? I'd die without ac
Old Jul 6, 2017 | 02:36 PM
So would I.
Old Jul 6, 2017 | 09:56 PM
Btw be safe in those wildfires.
zak0331
May 5, 2014 05:29 PM
Leadfoot
Feb 5, 2014 03:58 PM
kayle
Sep 25, 2009 05:49 PM
Omegaman
Oct 8, 2007 04:42 PM
omega73
Aug 17, 2006 07:24 AM
