Lincoln MIG Welder Problem
Old Apr 3, 2011 | 02:19 PM
My442's Avatar
Question Lincoln MIG Welder Problem
I have a Lincoln Weld Pak 100 MIG welder. I probably have used it about 6 times since I bought it.
Today, I was going to do some welding, and the wire will not feed. The feed wheel does not turn, and I can hear a loud click when I pull the trigger.
The fan is on, and it will weld with what ever wire is exposed, but will not feed.....tried everything.
Any ideas?
TIA
Old Apr 4, 2011 | 07:35 AM
442Harv's Avatar
Did you take the tip off and see if it feeds? Also is the tightner on? Also do you have the spool to tight?
shepo1
Oct 15, 2014 12:40 PM
Napoleon Solo
Jul 6, 2014 12:06 AM
dcwright70
Body work
15
Mar 13, 2013 06:30 PM
My442
Jan 6, 2013 07:17 AM
Eric Anderson
Dec 19, 2008 04:07 PM
