Which letter exhaust manifold?
Old August 11th, 2023 | 02:04 PM
rudeke's Avatar
Thinking of going through with building the 455 F block. Which letter exhaust manifolds could I use for it so it goes into the ‘75 Salon? Thanks in advance for everyone that replies. ER
Old August 11th, 2023 | 02:59 PM
rocketraider's Avatar
Oldsdruid
Depends on whether you're keeping the single exhaust with catalytic converter. If you're not, and you're going true dual exhaust, W & Z will work perfectly as that's what 73-74 455 Cutlass had. Otherwise you're kinda stuck with 75-76 455 manifolds, which have the crossover and the correct exit angle for the cat.
If you're going duals you also need to find a 73-74 GM A-body double hump transmission crossmember. Makes the job much easier and neater.
Old August 11th, 2023 | 05:01 PM
rudeke's Avatar
Thanks for the reply RR. No cats, and I have been thinking about the dual exhaust crossover. I have only come across one in since I have owned the car for around the last 12 years. Kinda of scarce. I am currently parting out a ‘75 and removed the single crossover. My neighbor, who is a welder by trade, said he cold combine two single and fabricate a dual. Have you ever heard of anyone doing this? ER
Old August 11th, 2023 | 08:26 PM
edzolz's Avatar
THIS ^^. I did the same thing for a 78 442 that I had.
Old August 12th, 2023 | 08:37 AM
edzolz's Avatar
You need to learn how to use the forum. You wanted a reply by e-mail but you have chosen to not receive e-mail in your preferences.
I did weld two crossmembers together to make a double hump. That was over 25 years ago and do not remember how I did it. A professional welder will know how.
FTolliver
March 28th, 2014 09:12 AM
atkinsom
May 29th, 2013 07:39 PM
wolfman98
October 27th, 2009 08:37 AM
the_boat
October 7th, 2009 12:32 PM
oldsracer
September 1st, 2009 04:24 AM
