Knock in 350. Need engine choice help
Old Jul 21, 2011 | 08:39 PM
pacho442's Avatar
hi have a motor knock in my olds 350 need advice have a torn apart 455 30 over Ga heads that needs a rebuild,can buy a olds 307 out of a hurst olds 140 k for $300 buy home rebuild 350 for a$1000 or a 403 with 100k for $500,any help would be great.
Old Jul 21, 2011 | 10:39 PM
Redog's Avatar
If I where you I would buy the 403 and then either tear down the 350 or put the 455 back together at a leasuirly pace. A "9" 307 has a little bit of power but I think the 403 is a better choice
Old Jul 22, 2011 | 05:54 AM
Rickman48's Avatar
If you use the 403, check the timing chain before installing, as they start going bad at about 80k - if it's been sitting, the water pump bearing seal usually dries out, too.
Both easier to do before installing.
BangScreech4-4-2
Feb 25, 2015 11:18 AM
delta_88_germany
Non-Olds Engines
Sep 28, 2014 05:44 AM
delta_88_germany
Brakes/Hydraulic Systems
Nov 2, 2013 05:06 AM
805cut
May 25, 2012 03:30 PM
walkthwalk92
Jul 21, 2009 08:30 AM
