key switch operation
Old Jan 11, 2011 | 09:15 AM
knighthawk's Avatar
From: from Wisc, then Texas, then Kansas, now back to Texas,
aftrer putting my steering column back together, ( I removed the 'nub' for the column shift) it seems that the iginition can only be turned off in the park position. Is this correct ? Of course I don't have the engine and tranny in, so I can't connect everything to be sure. It's just that while I rotate the column 'bowl' by hand, the key will onlyl go to 'off' when I turn the bowl all the way to left ????????
Old Jan 11, 2011 | 09:48 AM
Bluevista's Avatar
Registered
You should be able to turn the key to the off position in any shifter position. It only locks, which also locks the steering wheel and the column or floor shifter, when you put the shifter in park.
The key won't come out unless it's in park.
Old Jan 11, 2011 | 10:03 AM
knighthawk's Avatar
that's kinda what I thought. guess I'll have to take it apart again, and take a look
Old Jan 11, 2011 | 03:55 PM
knighthawk's Avatar
just needed to re-adjust the ignition switch, thanks again
new to this
Jan 17, 2012 07:59 PM
86ChebbyWagon307
Jul 5, 2011 07:09 PM
jpaulwhite
Dec 17, 2010 02:52 AM
Yeti
Aug 23, 2008 04:42 PM
