Exhaust manifold compatibility ?'s
I discovered the other day that I have a passenger side exhaust manifold gasket leak on my '73 CS. Now is as good a time as any to go with dual exhaust, but I don't want to use that block off plate for the crossover pipe. Is there a stock cast passenger side manifold I can use?
https://classicoldsmobile.com/forums...manifolds.html
In the forth post I have some pics....not sure if it is what you are after or not...
All factory SBO dual exhaust setups used the cap on the passenger side manifold, even the W-31s. The aftermarket manifolds are expensive and frankly don't look to be shaped any differently from stock. Your call as to whether or not they are worth the money. The cap is cheap.
$40 is waaaaaay out of line for this part.
Good luck
Jim
They are very well made and fit perfect.
I gotta weigh my options here. On one hand, after talking with a few old timey retired GM mechanics that are friends of the family (WHAT a WEALTH of knowledge these old guys have on 60's and 70's GM cars), they both suggested as a quick cheap fix to drop the manifolds and install a quality gasket. Certainly that is the cheap route to a fix, but I'm not sure how "quick" it would be as that's at least a 2 man job because everything has to move at the same time on both sides of the engine. But then again they warned that this may or may not fix the problem and I'm back to square one. Then on the other hand my engine builder says to get the Thorton manifolds and he will give me the dealer cost on a Pypes exhaust, installed (if I bring the Sam Adams). Oooh, what to do!
Don't get too excited over that center divider. It only goes about an inch or so deep. The BBO manifolds have true divided runners.
And for comparison, these are real W/Z BBO manifolds - no, you can't use them on an SBO.
I think you need a new pair of glasses, I agree they don't look much different on the out side but when you look inside they are defiantly bigger. The DS dump is larger (you have to look at the inside not the outside) than stock and if you don't think getting rid of that stupid looking 1/2 horseshoe on the PS doesn't help then I give up, your pictures are shot a a deceptive angle, if you had shot them from the top so you could see how much wider they are the would tell the real story. I was just trying to help.
My opinion is this. Not having actually handled these manifolds, I do like the fact that it has a center runner (No matter how deep it is or is not). I like the fact that the bolt holes look a tad beefier than the stock ones. I like the fact that unless someone from this site judged my car they would most likely not be able to tell they are not GM issue. Price is what you are willing to pay. I agree with both of you at least on some aspects of both of your arguments.
2blu442
Mar 7, 2014 06:09 PM
atkinsom
May 29, 2013 06:39 PM
