to jute or not to jute?
Location: from Wisc, then Texas, then Kansas, now back to Texas,
which works best : carpet, jute pad , AND sound deadner like Dynamat, or just carpet and Dynamat, or carpet and jute pad ?
It all depends what you expect in ride quality, how much you wish to spend, and how you intend to drive it.
I used all of the above, as my car will be used for longer trips. Cost of just the dynamat stuff was over 500 bucks.
The end of this thread gives my final review.
https://classicoldsmobile.com/forums...html#post50063
It is great when you travel long distances with someone or you like listening to music (and not blasting it).
Overall, the A body convertibles seem to be exhibit low wind noise with the top down, providing the ambient winds are not too wild. On a calm-wind day, they are very quiet.
Quieting the road noise through the body helps quite a bit, adding to the driving pleasure.
I used all three as well, there may be cheaper alternatives but you also do not have to cover the whole floor especially under the seats. I mentioned before not only does it limit noise, it limits vibration and even better heat, my car is so much more comfortable to drive now because of the lower temperatures
http://www.fatmat.com/
Here are some pics of my install.
https://classicoldsmobile.com/forums...tml#post224689
I just bought the bulk packs and went crazy.
Adam
jensenracing77
May 29th, 2015 01:20 PM
coppercutlass
March 2nd, 2015 02:49 AM
