Jetaway trans. Shifter cable
Old Aug 17, 2012 | 11:41 AM
shezoom's Avatar
i am restoring a 1967 cutlass supreme 2 door post car with a 330 cu. in. engine with a 2 speed jetaway transmission. the car has bucket seats with a console. i need the cable to connect the floor shifter to the transmission and the bracket to connect the cable to the transmission. can anyone help
Old Aug 17, 2012 | 11:57 AM
Mikes65's Avatar
If the 67 is like the 65 it is not a cable but a shaped rod held in place with cotter pins and washers at each end. I am sure I have a couple in my shop. Also I believe there is no bracket on the trans-just an extension off the shift point on the trans-a bent piece of flat metal with a hole for the rod.
Old Aug 23, 2012 | 07:23 AM
shezoom's Avatar
mike, the 67 is not like the 65. the 67 has a cable similar to the turbo hydramatic. the gm part number is 396327. i have a picture of it but i do not know how to send it to you. thanks
jkisaacson
Jun 16, 2014 08:38 PM
rcdynamic88
Aug 1, 2013 03:44 PM
dmberendsen
Jan 2, 2013 05:14 PM
Benji
Nov 2, 2012 05:04 AM
88hurstolds
Jan 1, 2009 07:50 AM
