Jet Hot coating colors, who has experience
Old Jan 24, 2019 | 04:44 PM
jensenracing77's Avatar
Does anyone have experience with Jet Hot? I am wondering what their satin silver looks like? I called them and I can't really get any pictures of a finished product. I need my coatings to look aluminum color. Not sure how close they would look? My other question is, if it lowers the temp as much as they claim, could I paint over the coating with high heat paint and it hold up.
Old Jan 27, 2019 | 03:16 PM
The Hedman Hedders on my 71 98 were thermal coated from the factory. While it isn't the Jet Hot brand I'm pretty sure it's the same coating. I can't comment on the Jet Hot colors but the coating on my headers does little for temperature reduction under the hood. The silver color has held up pretty good over 8 years though, with only a little wear and pitting. Hope this helps.
Old Jan 27, 2019 | 04:43 PM
marxjunk's Avatar
satin silver looks more like dull stainless than aluminum
Old Jan 27, 2019 | 05:28 PM
Do you know if any of their colors look even close to aluminum?
Old Jan 28, 2019 | 02:09 AM
76olds's Avatar
Hookers under Hood
Hedman uses Jet-hot to coat their headers. That's what they told me when I purchased mine from them. I got the ceramic coating, looks like aluminium to me. I think it helps to keep the heat down .
Old Jan 28, 2019 | 08:27 AM
Originally Posted by 76olds
I think it helps to keep the heat down.
I guess I'm not used to headers on other cars. The Hedman headers on my 71 98 are quite a bit hotter than stock manifolds. Of course, that's just using the WAG therom, I've never measured the temp with an infrared thermometer or anything.
Old Jan 28, 2019 | 07:51 PM
76olds's Avatar
Hookers under Hood
I haven't measured the under hoods temps either, although I did take out the weatherstripping that seals across the firewall to the hood. Gives me a little more airflow through the top of the engine bay.
So far heat hasn't been an issue in my case.
Eric
1970supremevert
Jan 7, 2014 01:07 PM
724drcutlass
Paint
Feb 16, 2012 09:33 AM
smcurro
Paint
Jan 29, 2012 02:31 PM
Hark442
Paint
Jan 25, 2010 05:27 AM
skubydobdo
Oct 31, 2008 05:30 PM
