jegs factory replacement oil pan
Old May 20, 2023 | 06:46 AM
deadeyejedi's Avatar
I bought this oil pan 555-50280 from jegs to use on a motor im working on but found it will not work if using your factory crossover pipe. i used this same pan on my 72 cutlass but that has headers .its good quality but not a factory replacement pan for a 350 olds.you can see in the first photo of the jegs pan it has an extra hump that prevents the crossover pipe from fitting properly .The second photo is a factory original.ill figure something out but just wanted to bring this up to make people aware of the differences.
Old May 20, 2023 | 07:01 AM
Thanks for the heads up.
I put a Milodon pan on the 455 that was in my 71 98 and it seemed to fit pretty well. I can't comment on ground clearance in a Cutlass but it never bottomed out in my 98.
Old May 20, 2023 | 11:03 AM
That's because this is a BBO pan, not an SBO pan. I guess I never thought about the crossover pipe clearance. My only single exhaust cars are 307s. The bulges are due to the internal baffle used on the BBO pans.
Old May 20, 2023 | 11:11 AM
So, they either: Listed the wrong one, shipped the wrong one or you purchased the wrong one (by mistake). Sounds simple enough to correct - other than time wasted.
Old May 20, 2023 | 11:13 AM
An incorrect catalog listing for an Oldsmobile part? I'm shocked, SHOCKED I tell you!
Old May 20, 2023 | 12:37 PM
well i fell for the old fits 350-455 trick!(yes technically it fits) I was only going to use the factory manifolds and crossover pipe to break in the new rings i installed . Ill macgyver something together for the break-in.
Old May 21, 2023 | 05:25 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
That is the better pan, yeah never thought about the crossover pipe. Obviously the BBO crossover pipe is longer and must have more clearance at the pan.
Bernhard
Jan 27, 2026 04:26 AM
Gene kerr
Jul 24, 2022 06:17 PM
Bandit60
Feb 9, 2021 06:36 PM
yellowrocket
May 28, 2019 03:13 PM
mmcilroy
Apr 30, 2010 05:55 PM
