It's Never a Good Day When...
Old Aug 18, 2014 | 05:07 AM
Olds Dad's Avatar
Collector of Stray 55's
....you end up coming home on the hook
Old Aug 18, 2014 | 05:18 AM
classicmuscle442's Avatar
Most old car owners have been there>>>>>hope its nothing serious (expensive).
Old Aug 18, 2014 | 05:29 AM
What happened?
Old Aug 18, 2014 | 05:48 AM
Olds Dad's Avatar
What happened?
Well, the first problem was that the loose nut behind the wheel popped the clutch too fast when he realized the light had turned green and he was busy playing with the radio...so it stalled out -
But, when I tried to start it the solenoid just 'clicks'
With the help of some friendly motorists (angry people behind me in the left-turn-only lane) I got pushed off into a used car lot.
Even with a jump and the old "whack it with a hammer" trick, the solenoid just clicked and the starter wouldn't even move.
I'm guessing the starter itself went, but I had no prior "warnings" from it - seemed to be just fine prior.
Old Aug 18, 2014 | 06:06 AM
Oldsguy's Avatar
Past Administrator
Heat soak from the headers then probably.
Old Aug 18, 2014 | 06:59 AM
Tedd Thompson's Avatar
If you have a stick couldn't you have had those same pissed off people push bump start your car or had they left you to your own devices... I think we all have been there done that and it sucks every time.....Hope it turns out simple....Tedd
Old Aug 20, 2014 | 05:02 AM
Olds Dad's Avatar
Update
Seems that my positive battery cable got too acquainted with my exhaust manifold and caused the problem.
Of course to get the starter out I had to drop the driver's side exhaust pipe and broke a bolt off in the exhaust manifold...and to get that out to remove the broken bolt I had to disconnect the steering column at the rag joint and remove the z-bar for the clutch.
But - I suppose it could be worse.
Old Aug 20, 2014 | 06:14 AM
Hopefully it will be smooth sailing from here on.
Old Aug 20, 2014 | 06:38 AM
OLDSRI's Avatar
Hey Gordon,
I noticed the RI Antique plate! Nice ride and glad you got the problem figured out.
We've had a good stretch of weather here in RI for cruising...
Bud
Old Aug 20, 2014 | 06:54 AM
Olds Dad's Avatar
Originally Posted by OLDSRI
Hey Gordon,
Bud
Thanks - yes, Saturday was a beautiful day for a ride on the bed!
Old Aug 20, 2014 | 08:10 AM
Gordon, glad to see things are coming along. It never ceases to amaze me how one problem leads to another and another and so on. And the cost of the repair goes from a 7 dollar cable to two days of of laying on your back doing things that ones body does not like.....Best of luck....Tedd
Old Aug 20, 2014 | 09:41 AM
Octania's Avatar
Oh that could have been a LOT worse.
There is no fuse in that huge wire
when it shorts out it becomes a welder/ heater.
Easy fix! Compared to a burned hulk.
slaughter442
May 13, 2012 08:59 AM
gearheads78
Feb 23, 2011 08:34 PM
redwingtour
Nov 9, 2010 06:45 AM
svnt442
Apr 29, 2010 07:14 PM
455 rkt
Jan 23, 2010 04:44 AM
