Interesting detail in 1966 Cutlass trunk floor
Old Jun 29, 2013 | 10:40 AM
2blu442's Avatar
This morning I was cutting some panels out of a 1966 Cutlass parts car that I want to weld into a 1967 442 project car. I spotted OLDS stamped into the trunk floor near the spare tire hold down. Do you guys think this is a factory stamp or was the trunk floor changed out sometime in the past? Most of these cars I've messed with have rusty trunk floors, so maybe I've just missed this detail in the past. John
P.S. this car has a really clean frame... with the exception of the munched left front ear! So if anybody needs a portion of a 1966-67 frame I'll be looking to cut this one up in the near future. John
Old Jun 29, 2013 | 11:29 AM
Grace Stinespring-Welch's Avatar
olds
i would say thats original.
Old Jun 29, 2013 | 01:23 PM
wmachine's Avatar
Trying to remember member
Factory. Here's mine. 1966 Sports Coupe.
Old Jun 29, 2013 | 01:35 PM
jaunty75's Avatar
Wow, this reminds me of a couple of old guys sitting around, hoisting up their shirts to show each other their surgical scars!
Old Jun 29, 2013 | 10:13 PM
rocketraider's Avatar
Oldsdruid
Wonder if it was a Fremont thing, since they were building all four carlines?
But then so did Framingham and Doraville.
Old Jun 29, 2013 | 10:34 PM
2blu442's Avatar
That might explain it, assembly plants where multiple companies were built.
I'd always thought the floorpans were the same between the different lines. But that clearly doesn't apply to the trunk floor, otherwise there would be no need to identify it as Olds.
Old Jul 1, 2013 | 06:42 PM
66-3X2 442's Avatar
Are you sure about Doraville? I've seen the OLDS stamp in a Framingham car before.
Old Jul 1, 2013 | 06:50 PM
slowolds's Avatar
Loose Radical
It wont be out of place on your 67. I have that in the trunk of my 67. Just on the other side of the pan.
Old Jul 1, 2013 | 07:13 PM
Run to Rund's Avatar
My Lansing 66 has it. My Fremont car doesn't and the raised area is shaped differently, extending farther back.
Old Jul 1, 2013 | 07:31 PM
hurst68olds's Avatar
Here's the floor of my November '65 Fremont, CA built '66 442 - no "OLDS".
Old Jul 1, 2013 | 07:53 PM
stan 65 cutlass's Avatar
ALIENS!
Old Jul 2, 2013 | 06:24 AM
wmachine's Avatar
Mine is Lansing too. But it may have been a stamping plant function, not of assembly plant use.
And it is entirely possible that there is no real "use" of it.
Old Jul 2, 2013 | 09:51 AM
66-3X2 442's Avatar
I'm pretty sure it was for assembly identification. The Chevelle uses a shorter trunk floor pan and will not fit an Olds. This would probably be a Fisher Body ID don't you think?
Old Jul 2, 2013 | 10:42 AM
wmachine's Avatar
Sure, that is still a possibility. But the Lansing cars have it and don't need it for that purpose. I don't know if they all have them or not. It is guess at best, regardless.
jon1957
Body work
16
Nov 2, 2018 09:10 PM
jstrits
Feb 7, 2016 11:33 AM
RAMBOW
Aug 19, 2012 09:51 PM
m455sx
Paint
23
Dec 30, 2011 06:19 PM
Bunser
Mar 27, 2010 10:29 AM
