Installing W-30 Ducts in Core Support 67 442 any pointers
Old Feb 20, 2017 | 11:06 AM
lemoldsnut's Avatar
This weeks project will be cutting the openings and installing a new reproduction set of "OAI" (outside Air induction) ducts in the core support of a 67 442. This core support is out and after I get all the work done to install the ducts it will be sand blasted and primered and painted then all will be reassembled. If anyone has any advise or pointers on doing this I welcome input.
Thanks in advance
Larry
lemoldsnut@aol.com
Old Feb 20, 2017 | 03:14 PM
Larry, I'll send you an email.
Old Feb 21, 2017 | 11:36 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
What would be really slick is to source someone to make you a die or a knockout kit for this. I'm sure other 67 owners would be very interested. As you know the factory holes were die cut whereas the Track Pac cars were crudely cut by the dealer or the customer. That said, it leaves the cut style wide open.
Another option if you wanted to go the die cut route is to find a competent machine shop that has the ability to die cut metal, or has a larger mill to jig it into for precise cuts. I wouldn't think this labor would be cost prohibitive, especially since the support is mobile. I guess it comes down to what you're looking for as the end result. Drill and careful cutting then finishing with a die grinder could be another solid method?
Does anyone possess a picture of both a factory and customer cut support? I have or had a factory picture but can not locate it.
Lem take pictures and share, please.
Old Feb 21, 2017 | 12:13 PM
Found the Track pac support pic. Note the rough edges when the pic is enlarged.
Consider having the support powder coated too. Budy did this with a 20% (I think) flattener and it turned out great. Much more durable than paint. Wasn't expensive either.
Old Feb 21, 2017 | 12:27 PM
Oldsmaniac's Avatar
There is factory literature with the template and possibly was also in the Track pack kit when purchased. The isn't a whole lot of room for the bezels with headlight buckets installed and trim so that pretty much outlines where the cut should be. The template does show where holes should be located also for mounting. I cant put my hands on it though.
Old Feb 21, 2017 | 03:41 PM
lemoldsnut's Avatar
I got the template. it is all marked out and ready to cut will work on the tomorrow. Jon Mott sent me some pics of the W30 I found him a few years ago it has the stamped one. I will be very careful to do a good job and will post pictures as I go.
Thanks for the input.
Larry
Old Feb 21, 2017 | 05:03 PM
RandyS's Avatar
When I did the cutouts on my 66, I marked it and cut very carefully with a new 4" cutoff wheel. It came out almost perfect. Little touch up with a fine file and it looked almost like it was stamped.
Old Feb 21, 2017 | 05:30 PM
marxjunk's Avatar
i dont know the gauge of the metal..but looks like a job for a nibbler...a little practice before hand but, when i worked on the line, i got really good with one...
Old Feb 23, 2017 | 01:44 PM
lemoldsnut's Avatar
After getting some input from those who have done it and looked over the factory stamped ones from the car Jon Mott had, I made the first cuts today. Roughed in yet but pretty close. Drilled the corners and then used a die grinder with a cut off wheel. Will file a little to make it real nice.
So far I am pleased with the results.
Larry
Old Feb 23, 2017 | 02:09 PM
Cincinnati Rick's Avatar
Looking good Larry!
Old Feb 23, 2017 | 03:22 PM
Nice work, looks like they belong there.
Old Feb 23, 2017 | 04:55 PM
RandyS's Avatar
Nice job, a little paint and it will look like it came that way!
Old Feb 23, 2017 | 06:32 PM
tomxk8's Avatar
nice job Larry!!
jensenracing77
Jan 25, 2018 04:16 PM
lshlsh2
Nov 30, 2016 09:45 AM
72notchback
Apr 27, 2013 02:41 PM
Flye
Apr 3, 2013 11:38 AM
jensenracing77
Apr 21, 2010 07:46 AM
