Gents
Is there a way to identify the steering box on a 69 Cutlass? I believe mines not orginal but have nothing to compare it against, I have the numbers GP50004 and 500 Series stamped on it.
The steerings shocking and I have replaced everything from the box to the wheels, which has made an improvement but its still not right, so once I've had the laser alignment done I'm looking to the box as a potential culprit
Feels loose, if you dont really concentrate on steering when driving, the car wanders and when you put power down its difficult to hold in a straight line. I've replaced that bar, all the tie rods and the idler arm with new Moog parts as most were very worn and I had hoped, that would have cured it but no. Wheel bearings are fine as well. So next stage is 4 wheel alignment, need to anyway after changing tie rods etc. It also feels 'jerky' when reversing on full lock and doesnt like turning sharply at parking speeds at all, almost feels like the front tyres are flat.
I've not had her long and the trouble is shes had so many upgrades, Wilwood discs alround, hotchkiss sports suspension, 18" wheels, which I also now find rubbing the lower arms, so I'm thinking spacers on the front, I'm checking everything and have no reference to anything apart from you Guys on here or as much info as I can on the web, I do have the Chassis Manual though.
Going to get that wheel alignment may be a blessing in disguise for you, and may only cost you a nice tip for some sound advice as was the case for me.
My car drives pretty straight and feels fine for the most part, although I do get a bit of a rumble at high speeds. Just for peace of mind I went to get an alignment, they did a visual inspection before anything. He jacked the front of my car up and grabbed the front tire at 9 o'clock and 3 o'clock and jostled the wheel back and forth. When shaken with some force the wheel has a bit more play than it should. He showed me where the concerns were, and recommended not wasting money on the alignment till the issue has been addressed.
My center links fittings are worn and the grease fitting is broken, no amount of adjustment will remedy that.
In your case maybe the new parts just need to be more properly calibrated and a extensive alignment will do the trick.
Reason: wording
