ideal running temp
Old Jul 11, 2013 | 07:10 AM
cmyolds442's Avatar
ideal running temp
Hey what would be the ideal running temp and oil pressure on my 1970 442 with a fresh 455 30 over with a mild cam right now it will run about 200 and the oil pressure is about 25lbs after it warms up thanks in advance
Chris
Old Jul 11, 2013 | 07:50 AM
Your initial oil pressure cold should be 50+lbs, 25 warmed up is fine. Your 200 degrees @ operating will vary based on outside air temp. In winter it should stay pretty close to what your thermostat is.
Old Jul 11, 2013 | 07:57 AM
cmyolds442's Avatar
I have close to 60 lbs on cold start and temp fluctuates between 185 and 200 I have a 180 thermostat in the car and everything is new radiator hoses fan clutch water pump I really just want to make sure everything is ideal on the engine I have about 300 miles on it since the rebuild
Old Jul 11, 2013 | 08:16 AM
That's a good operating temp at idle, and it should drop lower at speed.
Old Jul 11, 2013 | 08:27 AM
cmyolds442's Avatar
Yea it drops down while moving since I spun the main bearing last year its been in my head that I'm going to blow up even though I had everything rebuilt
Old Jul 11, 2013 | 08:29 AM
If it drops when you get moving, then you need a better fan, fan clutch, or fan shroud.
Old Jul 11, 2013 | 08:45 AM
cmyolds442's Avatar
Eric my fan shroud does need to be replaced but everything else is brand new
Old Jul 11, 2013 | 09:02 AM
New doesn't matter. Many fan clutches are bad out of the box.
That fan should blow your hair back at idle when the engine's hot.
Remember that an idling engine makes a LOT less heat than an engine under load, so if it won't stay cool at idle, there's not enough air blowing through the radiator.
Carl, uk
Mar 13, 2014 05:43 AM
69ishHoliday
Nov 25, 2013 04:03 PM
1971viking
Apr 17, 2013 09:00 AM
54oldz
Jun 20, 2012 07:13 PM
Emreozd
Feb 19, 2012 06:27 AM
