id my rear
id my rear
this was in my 72 Cutlass S
m stamped on the pumpkin
Is this a 8.5 10 bolt o type axle that would be correct to put into my 71 w30?
Just by the count method, it is a 3.42 gear limited slip...
thanks for the help!
Ted
Ted
more details
Yes that is an 8.5" housing. However you do not show the shock mounts. Make sure that this is 71-72 style not 73 & up. 73 has shock mounts on opposite side of housing & is wider.
What is the code on the axle tube?. It might be 3.42 now but it likely was not originally.
Fyi
That is a 71-72 8.5" housing as the shock mounts are rearward of the axle.
Be sure to pull the cover to confirm gears. 3.23 & 3.42 spin about the same.
Good luck. Either a 3.23 or a 3.42 posi is very nice rear for your project.
Luck of the Irish that it was in the S!
Ted
orthoK
May 16th, 2011 10:10 PM
Nor Cal Andy
April 1st, 2011 07:13 PM
