id my rear
Old Jul 20, 2014 | 06:11 AM
sammy's Avatar
Sammy70 455 Supreme
id my rear
this was in my 72 Cutlass S
m stamped on the pumpkin
Is this a 8.5 10 bolt o type axle that would be correct to put into my 71 w30?
Just by the count method, it is a 3.42 gear limited slip...
thanks for the help!
Ted
Old Jul 20, 2014 | 06:23 AM
oldsmobiledave's Avatar
more details
Yes that is an 8.5" housing. However you do not show the shock mounts. Make sure that this is 71-72 style not 73 & up. 73 has shock mounts on opposite side of housing & is wider.
What is the code on the axle tube?. It might be 3.42 now but it likely was not originally.
Old Jul 20, 2014 | 07:11 AM
sammy's Avatar
Sammy70 455 Supreme
thanks...I will have to clean to find axle code
Old Jul 20, 2014 | 07:45 AM
Fyi
That is a 71-72 8.5" housing as the shock mounts are rearward of the axle.
Be sure to pull the cover to confirm gears. 3.23 & 3.42 spin about the same.
Good luck. Either a 3.23 or a 3.42 posi is very nice rear for your project.
Old Jul 20, 2014 | 08:01 AM
sammy's Avatar
Sammy70 455 Supreme
Thanks Dave for your help....!
Luck of the Irish that it was in the S!
Ted
455cutlass1969
Drivetrain/Differentials
Apr 14, 2012 08:20 PM
Oly
Mar 2, 2012 12:01 PM
orthoK
May 16, 2011 10:10 PM
Nor Cal Andy
Apr 1, 2011 07:13 PM
