I screwed up- cut the dash
Old May 14, 2013 | 07:49 PM
Mochi's Avatar
Hey folks. It's been a while.
Lorayne got a stereo upgrade today and when I first installed the aftermarket deck 2 years ago I cut the dash :-( now I'm regretting it and was looking for option to return her to the stock look. Buying a dash is an option but I assume a lot of work to replace. Are there any kits to put the original radio back in, or aftermarket install kits I can use to clean it up?
Old May 15, 2013 | 03:43 AM
W70442's Avatar
I'm sure one of the guys here that parts out cars can hook you up with the metal radio section of the dash you'll need to repair that part. That would need to be welded in.
You already know you need a new plastic dash piece. That, you can most likely do yourself. You'll just have to remove the plastic dash piece and the pad. It really isn't all that hard. There are only 7 speed nuts holding the dash on.
As for installing an aftermarket stereo once the dash is back to stock, I have been building stereo (and gauge) housings that are based on the 68-72 Cutlass factory 8 track tape player housing for about 14 years now. Here's a link to an older ad I have here on this site for them. Let me know if you have any questions about the housings if you are interested in going that route.
https://classicoldsmobile.com/forums...-housings.html
Good luck,
Randy
Old May 15, 2013 | 11:42 AM
Mochi's Avatar
No link :-) my idea now is to relocate my pressure temp and volt gauges to fit or cover up the hole and then use your 8 track mount to go under the dash.
Old May 15, 2013 | 12:31 PM
W70442's Avatar
My bad.
I edited the post above to include the link I mentioned. Sounds like you found the ad or already knew about them and have a plan.
Drop me a line when you're ready for the housing. w70442@hotmail.com
Old May 15, 2013 | 12:57 PM
Mochi's Avatar
Originally Posted by W70442
My bad.
Thanks, and yup we spoke once before about the mount when I was exploring stero options :-) I'm still debating on what I want to do with the hole lol. Do you know a place I can find the dash piece? Or a delete panel?
Old May 15, 2013 | 01:26 PM
Mochi's Avatar
Email sent
Old Jun 4, 2013 | 07:18 PM
Mochi's Avatar
Thanks to W70442 and his awesome stereo mount. I think I salvaged my dash.
yamahondarider
23
Apr 20, 2018 06:31 AM
RAMBOW
Jun 26, 2009 08:38 AM
IDAS 69
Apr 19, 2009 05:46 PM
gearheads78
Feb 17, 2009 04:17 PM
DJMatthews
Dec 12, 2006 06:36 AM
