I made my car & Olds look bad tonight!!!! SMH!!!!
Old May 28, 2010 | 07:51 AM
  #41
Aceshigh's Avatar
Originally Posted by The Stickman
I thought the SBO Olds was lighterthan the sbc.I haveseen numbers that say so. Are they incorrect?
You're right. I thought with the Olds 350 being bigger, it would be heavier. It's not.
Then again, the Olds weights specifically state "No Flywheel" so I'm not sure if the Chevies had them or not.
Small Blocks > Olds having no flywheels.
Olds 330-400 560lbs (5) low deck, w/accessories, no flywheel
Chevy small block V8 575lbs (generic for '60s-'70s motors)
Chevy small block LS1 460lbs (185)
Big Pig-blocks > Olds having no flywheels.
Chevy 454 675
Olds 400-455 620 [/B] (5) high deck w/accessories, no flywheel
http://fixrambler.com/engineweightchart.txt
The LS series are 125lbs lighter with the Aluminum heads, block, and composite intakes.
They weigh 215lbs less then the BBC.
The Gen III heads flow the same as BBC's and BBO's do. ~250cfm
Olds C head figures
The Gen IV heads flow ALOT more in stock trim at 300-320cfm.
Granted, not as much torque in stock trim, but VERY easily made with bolt on's........and they get great MPG.
Of course people will state any motor can with EFI, but the reality is not for $2,000 in a junkyard scrap pull.
Like I said before, head flow characteristics of modern GM blow away any classic engines'......for just $500
Old May 29, 2010 | 10:24 AM
  #42
88 coupe's Avatar
Junior Member
Continuing this useless thread hijack, with my apologies to the OP:
........ it's not as much fun as a blown 394 Olds in an Altered coupe...
One of my favorites.
Originally Posted by Aceshigh
Originally Posted by 88 coupe
........ And rocketraider should stop feeding the troll.
Boy you Olds boys are really sensitive aren't ya ???
Can't handle the topics of discussion when comparing GM brands.
Got nothing to add to compare engines in a GOOD conversation so you start with the name calling.
Three assumptions that have no basis in fact.
The content of your first post, and its obvious lack of relevance to the topic, is the basis for my statement.
If you wish to discuss it further, send me a PM.
Norm
Old May 29, 2010 | 01:56 PM
  #43
Wyze's Avatar
Anyway fellas, I changed my points to HEI and all I can say is WOW!!!!! Such a difference, I gotta get a light and set the timing along wit a couple more things but as far as I can see, it's on tomorrow night!!!!!!
I'm hoping to send some guys back home to make some changes like I had to!!!!
Old May 29, 2010 | 07:57 PM
  #44
Redog's Avatar
Yeah they people are right, a SBC is easier & cheaper to build.
IMHO it's more fun to build a motor or car that isn't "Off-the-shelf" like those Chevy and Ford boys have it
You have a stock 68 Cutlass and you lost to worked Chevy's. Yeah that's going to happen.
Throw some 3.73's or 4.10's if you have an OD trans. That 600 CFM Holley isn't helping you too much either. Put a 770 on that intake.
Block crossovers, hotter cam, higher stall.
I'm always made fun of by the little ricers at the track for racing an Alero, oddly enough they stop laughing after I beat them.
I smoked a 05 Mustang off the line once, if it was an 1/8 mile track I would have won by almost a car lenght. He pulled after the 1/8 and won (it was time shots anyway) First round, he liked left lane, I like right, I was in the staging lanes already, he pulls up and pulls BEHIND me
Bottom line, don't fight a fight with a car or driver that's out of your leauge
Old May 29, 2010 | 07:59 PM
  #45
Redog's Avatar
You need more that an HEI
Old May 29, 2010 | 08:39 PM
  #46
Wyze's Avatar
I just left from off Goodfellow, and all I can say is I'm looking for that Malibu!!!!
Ran the Cutlass and won by 5 cars then the SS and beat him by 2!!!!!!!
I haven't even set the timing yet!!!
I'm gone clean the plugs tomorrow cause the #1 was filthy!!!!
I can't lie everyone was very impressed at this lil rocket!!!!
ReDog you say a 770, you don't think that's to big for a stock rocket????
Old May 30, 2010 | 12:58 PM
  #47
Aceshigh's Avatar
Stock cam and valvetrain.....yes. Way too much.
Your VE or Volumetric efficiency of a stock engine requires less then a 600cfm combined with the low revving capability of Olds engines.
Here, experiment with this.
http://www.gtsparkplugs.com/CarbCFMCalc.html
Doing 14's ?? Modified Alero's fall into the same bracket as ricers once they do body kits, spoilers, fart cans, etc.
So do modifiied domestics such as Dodge Neon's, Chevy Cavaliers, Pontiac G6's, etc.
Some do look pretty cool though. I saw a red riced out Alero that was pretty f'n cool lookin IMO.
But I know most of your older guys won't adapt. This is similar but it had a spoiler.
Old May 30, 2010 | 04:22 PM
  #48
silverriff's Avatar
1972 Cutlass 455
Switching over to an HEI would not have made that big of a difference, unless the old distributor was so far gone....especially if you have not even touched the timing. It may just have been a placeebo/confidence booster. I had the same thing happen when I put in a K & N air filter. It was soooooo much
faster!! Just seems alittle odd....Wyze, on your other questions about this transplated Rocket, you were saying that it was running like crap. What did you do to fix it? Was it the carb that you had taken off the old engine? I'm just curious why doing something like putting in an HEI was like bolting on a supercharger. If so maybe I need to switch to HEI!
Old May 30, 2010 | 09:45 PM
  #49
Wyze's Avatar
Before I switched to HEI I took the car to the shop and they said they set the points, adjusted the carb and set the timing!!!! The was on Friday, by mon it was running back like crap!!!! Believe me it was those points!!!!
My timing is still off, when I mash the gas it seems as the car takes a deep breath (falls on it's face) then takes off!!! Sounds like woomp----pause------- wrooooom it's outta here!!!!
Soon *** I let off the gas it starts farting!!! (backfiring)
I think that's coming from the carb!!! Yes I took that off the old motor that was making the same sound!!!!!
Before I couldn't get rubber, now it's super easy!!!making all the noise in the world and didn't see no smoke, now Im laying streaks on the ground and smoking **** up!!!!
Old May 30, 2010 | 09:51 PM
  #50
Wyze's Avatar
Almost forgot to say something, I had a guy a my buddys job (NTB) set the timing!!! He said he set it to 12!!!! (stock) I drove the car around and it didn't haul *** like before so I had him put it back to 16!!! I think I just need to take it to a performance shop and have them hook it up!!!
Old May 30, 2010 | 10:37 PM
  #51
svnt442's Avatar
You need to set it to 20° and go from there. The HEI uses a different advance curve than the points distributor does.
Old May 31, 2010 | 05:58 AM
  #52
silverriff's Avatar
1972 Cutlass 455
Yeah I had to do the same to my timing. My stock timing is 8 btdc and and I knocked it up to 10. My engine is in ok condition, just tired. You sometimes have to compensate for 40+ years of wear and tear. Well in any case glad to hear you got to smoke some chumps out on the street. Here in Baltimore, we have speed cameras EVERYWHERE, so it isn't as easy as my dad said it used to be! My sister's ex boyfriend got a $500 ticket a few months back for doing 90 in a 45 miles per hour zone. He had just gotten a new "chip" put in his 1999 Mustang and just HAD to test it out. Serves him right for driving a Ford!
Old May 31, 2010 | 07:07 AM
  #53
agtw31's Avatar
spray the crap out of your motor
youll win at least one race
Old May 31, 2010 | 07:41 AM
  #54
Wyze's Avatar
It goes down here in St.Louis!!!!! We've got several places we go to run, most popular is Hall st. But it's to many people who come to watch, which normally leads to a huge crowd and the cops showing up before long!!!!!!
I wish you guys could see what a nice Sunday is like here!!!
St.Louis is very big on the Cutlass, all different years!!!! There are some many nice ones here!!!!!
I was just outside checking over my charging system ( which is not working properly)!!!
I've got 2 alts and both of them are only putting out around 13.50,
is this normal for a external regulater?????
Old May 31, 2010 | 09:15 AM
  #55
svnt442's Avatar
That's not the alternators issue, but the voltage regulator.
Old May 31, 2010 | 12:25 PM
  #56
silverriff's Avatar
1972 Cutlass 455
Yeah there are no real places to race around here...the cops have been going at streetracers in force lately. Mainly due to an incident about a year ago. There is a pretty remote road right outside the city that racers and watcher would gather on, and about a year ago a racer driving something weird, like an old Crown Vic lost control and plowed into the crowd killing I think 12 people? Something like that? It was a lot. So ever since then this whole area is locked down and if a cop catchs you doing something like that, you go away for A LONG time. Just be safe!!!
Old May 31, 2010 | 12:26 PM
  #57
Wyze's Avatar
So I'll get another reg today!!!!
Tonight I'll get off in some chebbies asses!!!!!
Lol
Old May 31, 2010 | 12:29 PM
  #58
Wyze's Avatar
Lol!!
Old Jun 1, 2010 | 05:09 AM
  #59
agtw31's Avatar
Lol!!
just get this
Old Jun 1, 2010 | 06:59 AM
  #60
Wyze's Avatar
They ain't ready for that!!!!
I wouldn't have a stock motor!!!!
Old Jun 2, 2010 | 08:31 PM
  #61
young olds's Avatar
how'd the racing go?
Old Jun 2, 2010 | 09:58 PM
  #62
Wyze's Avatar
We were so wrapped up in the car show and riding that we didn't run!!!!
Old Jun 2, 2010 | 10:02 PM
  #63
young olds's Avatar
Oh, well next time you go make sure you let me know how it went.
Old Jun 2, 2010 | 11:51 PM
  #64
Aceshigh's Avatar
Everyone is stock in a race.
You'll learn that everyone lies about mods done to their car in races
If you catch them in a lie , they will say something like ......
"When i said stock , i mean bottom end is all stock".
It's all part of the Hustle.
rocketraider
Dec 15, 2012 09:00 PM
RetroRanger
Body work
Nov 29, 2012 11:09 AM
Wyze
Dec 14, 2011 07:30 PM
The Stickman
Feb 11, 2010 04:47 PM
Oldsguy
16
Nov 30, 2008 04:21 PM
