Hurst Dual Gate
Old Feb 28, 2014 | 11:03 AM
69CutlassAlex's Avatar
Hurst Dual Gate
Hello All,
Will any hurst dual gate be compatible with my TH400? I know GTO also had a Hurst Dual Gate, will a GTO HDG work in my '69?
Thanks,
Alex
Old Feb 28, 2014 | 12:12 PM
sicky olds's Avatar
NôôB
Should be just the shift cable that you would have to check on. All 69 H/Os had the dual gate shifter with the TH400.
And i dont see why not that it would work with the GTO shifter.
Old Feb 28, 2014 | 12:26 PM
Dave Siltman's Avatar
Better check the shifter's mounting base/plate. I know they had Dual Gates in A-bodies after '72 which had a different floor than the '64-'72s. Also the handle differs on Pontiac applications.
Old Feb 28, 2014 | 12:34 PM
Thanks, Im currently gathering all of the supplies to switch from a bench and tree shifter to Buckets and a center console most ideally with a Dual Gate. Just trying t make sure this isn't some huge difference between Pontiac and Olds HDG that would make it extremely difficult to interchange.
Old Mar 1, 2014 | 10:50 AM
'69CutlassVert''s Avatar
Oh man seriously.......I struggled with this so long and decided to stay with the bench/ tree combo. Keep us posted on how it goes. What's your budget looking like?
Old Mar 1, 2014 | 12:22 PM
For the 4 years Ive owned the car Ive always wanted to make the change. Ive finally made the first leap. I bought a 69 Center Console. Im looking for buckets seats and a DG. There seems to be a variety of Dual Gates some for olds, Pontiac and Chevy and I wanted to find out if they were somewhat interchangeable. Im not going as far to change the steering column or speedometer....yet. Looking to spend 300-550 on Bucket Seats, which is reaching a bit but OPGI makes a decent repo-seat if I cant find something else. Looking to spend up to 300 on a DG preferable with the majority of components and Im contemplating on how to inlay the '70 DG Top Plate into the 69 Top Plate.
Old Mar 1, 2014 | 12:48 PM
Call Jim at 336-766-7845. He owns Classic Olds LLC in Clemmons, NC. Great guy, fair, knows his stuff, prolly got everything you need in stock for the job.
Old Mar 1, 2014 | 12:49 PM
Thanks, ill give him a call later.
RS3SDL2MG
Hurst/Olds
Oct 7, 2009 05:42 PM
DanMan82
Jan 15, 2008 11:09 PM
Chuck C
Dec 7, 2004 10:14 AM
