How stupid am I?
Old Nov 6, 2018 | 12:41 PM
yellowone's Avatar
How stupid am I?
I have a 1972 Cutlass Supreme. For the life of me I cannot get the bulb out of the trunk light assembly. I have the assembly in my hand and just can't get the bulb out. I don't want to wreck the assembly. Is it hot melted into the assembly? I just cannot believe I can't replace a damn bulb.
Old Nov 6, 2018 | 01:14 PM
rocketraider's Avatar
Oldsdruid
If it's the type that mounts to underside of deckllid, have you taken the metal cover off? Snap it off and bulb should be easy to access. Use latex gloves so you don't damage yerself if the bulb breaks.
The ones that mount on the hinge can be a PITA.
Old Nov 6, 2018 | 01:43 PM
Note, you have to push the bulb into the socket and then turn. And if the bulb does break, use a needle nose plyers to twist the metal bayonet from the bulb socket.
Old Nov 6, 2018 | 03:19 PM
ankerclanker's Avatar
cut a 6 or 7 in long piece of 1 or 1 1/2 heater hose, push it down onto the bulb and turn, shoot a little wd-40 into the socket. works great on front turn signals of 65 cutlass.
Old Nov 6, 2018 | 03:27 PM
oldspackrat's Avatar
If it is the correct light for your car I use a small flat screw driver or if you have a small hook tool that will work to get under the metal part of the bulb & pry it out. It should not be the kind where the bulb pushes down & turns, that is the 1969 & older style.
Old Nov 6, 2018 | 04:06 PM
My mistake, thanks for the correction.
Old Nov 7, 2018 | 04:58 AM
This! WD 40 or electronics cleaner should clean out the 40 years of grime keeping the bulb in the socket. When you install a new one you can use a little di-electric grease so when your kids replace that bulb in another 40 years it won't be a pain to remove.
mitchy
Feb 8, 2016 09:34 AM
gofastdontcrash
Aug 9, 2015 10:49 AM
66 Olznut
Jun 19, 2015 01:47 PM
Massdelta
May 27, 2014 02:14 PM
dingusboy
May 26, 2009 10:11 AM
