how to remount a air compressor
Old Nov 17, 2010 | 05:06 PM
1983oldsmobiledelta's Avatar
Question how to remount a air compressor
how to remount a air compressor on 1983 delta 88 307 V8 i got two bolts one is shorter then the other and one has a nut with it does the shorter one go on top are the bottom and wheres the one with the nut go thanks if you need pics i try take some asap thanks for any help
Old Nov 18, 2010 | 12:38 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
AIR pump?
or ac COMPRESSOR?
The air pump should have 2 bolts and both should have nuts to be installed on the back side.
Bolt length doesn't really matter on those, as long as they go all the way through.
AC compressor is much more involved, with adjuster bolts, long bolts, and spacers.
Gunfreak25
Feb 1, 2011 03:07 AM
lil_no
Jan 14, 2010 01:19 PM
Hairy Olds
Jul 12, 2009 09:21 AM
1FSTLS1
Dec 28, 2007 07:45 PM
jaco
Jan 5, 2007 08:57 PM
