Midland air compressor on my 455
Old Jan 28, 2011 | 11:26 PM
Gunfreak25's Avatar
I am installing a 2 cylinder air compressor onto my 1970 455 Olds engine. This is so I can get power brakes back in my truck. Like most truck compressors it must be plumbed into the engine for coolant and oil for lubrication. I have the oil feed and oil return lines figured out. That will be easy.
What I can't seem to think of is what I can tap into for the coolant supply and return line?
Here's the compressor in question..
http://www.alfaheaven.com/MilitarySe...Pic/M_AirC.gif
Old Jan 29, 2011 | 03:14 AM
jensenracing77's Avatar
for the brakes you need a vacuum pump. have you tries a larger vacuum reservoir? that may be all you need.
Old Jan 29, 2011 | 03:18 AM
Yellowstatue's Avatar
I believe his truck has compressed oxygen powered brakes......for coolant lines try the heater hose attachments...
Old Jan 29, 2011 | 07:53 AM
panos's Avatar
for the oil i would use something like that http://www.jegs.com/i/Perma-Cool/771...oductId=745584
Old Jan 29, 2011 | 10:09 AM
Gunfreak25's Avatar
That's something like I was going to use, couldn't find it though as I had no idea it was called a sandwich adapter. Thanks! The truck has standard hydraulic brakes but they are assisted by compressed air instead of engine vacuum, this air power comes from the Air Pak or Air Hydraulic Cylinder.
I tried to remove the heater core on the rear of the intake and I simply could not get it to move. Today I may try heating the threads up with a torch, always works!
Old Jan 29, 2011 | 10:33 AM
panos's Avatar
Dont know wich intake you have, but most of them have several threaded holes on the front wich are plugged,except the one for the temp.sensor.
Old Jan 29, 2011 | 08:14 PM
Gunfreak25's Avatar
Another question, will the radiator that came with this truck be sufficient for my application? It's a 1967 Harrison down flow 2 core and aside from being plugged with sediment and crap it's in great shape. I currently have it off right now. I have straightened every single fin and there's only a couple bent tubes. This one has the tranny cooler lines on the bottom too. The summers here can get up to 117 and I want to be darn sure things are cooling properly. The 455 has the stock 6 blade clutch fan and there is no fan shroud. I will be giving it a THOROUGH flush job before it goes back on the truck.
The application....
Old Jan 29, 2011 | 09:04 PM
oldsguybry's Avatar
NOVICE car nut
cool truck , can I borrow it ? we have alot of snow coming our way here in WI.
Old Feb 1, 2011 | 03:07 AM
A two row doesn't sound like much of a rad for a 455...a rad in a Cutlass is about 28 inches wide and 20 inches tall, with four rows with A/C ...if your rad has a greater area then it might be OK but I would consider something a little more adequate... My neighbour has a ten wheel drive tractor that looks like your truck that he races up and down the fields with pulling a 45' trailer, but we won't be seeing that one until spring...I could check his rad situation and see what gives...I think it has a six in it...
Last edited by Yellowstatue; Feb 1, 2011 at 03:12 AM. Reason: Blinding flash of recollection!
Gunfreak25
Apr 4, 2011 03:39 PM
lil_no
Jan 14, 2010 01:19 PM
Hairy Olds
Jul 12, 2009 09:21 AM
1FSTLS1
Dec 28, 2007 07:45 PM
jaco
Jan 5, 2007 08:57 PM
